MR2 Reverse Lights
mistertwo
This has been a problem that's been forming for a while now on the MR2
When I used to stick the gear stick into reverse, there was a beep that came on - when this beep sounds, the reverse lights come on. Then, this beep was taking a few seconds to come on once in reverse and then it would only come on every couple of times I put it in reverse and now, no beep at all and no reverse lights.
I've tested bulbs etc. Any ideas as MOT is coming up?
Cheers
Josh
Iirc you don't need a reverse lamp for a MOT.
That is correct I believe, however all Lights fitted to the car have to be operational for the MOT.
So if it didnt have any lights for the reverse - no issue,
if there are lights and they don't work, think that's then "an issue"
Sounds switch related though, and hopefully "the big push" will sort that out!
