jon_dragon Posted January 11, 2011 Share Posted January 11, 2011 I need new brakes on the front of my '95 n/a but without taking the discs off I can't accurately measure them. If it Helps, the pads are the conventional type, ie not the square ones with pins through the top. Any ideas? Link to comment Share on other sites More sharing options...
Awisto Posted January 11, 2011 Share Posted January 11, 2011 296mm, same as GS300 and a few others Link to comment Share on other sites More sharing options...
EMPEROR Posted January 11, 2011 Share Posted January 11, 2011 small brakes front - 296mm small brakes rear - 307mm big brakes front - 323mm big brakes rear - 324mm http://mkiv.supras.org.nz/specs.htm There is a table "Brakes" where you'll have all the info. Link to comment Share on other sites More sharing options...
jon_dragon Posted January 12, 2011 Author Share Posted January 12, 2011 Awesome! Thanks buddy :-) According to that chart I'm on the small brakes. Link to comment Share on other sites More sharing options...
Dnk Posted January 12, 2011 Share Posted January 12, 2011 (edited) Post a pic of your calipers as the j spec and uk spec are totally differant These are uk spec fronts Edited January 12, 2011 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
