imi Posted June 16, 2005 Share Posted June 16, 2005 HI Guys, I am going to explain everything in some detail so this might be long. All started off with me changing the speed converter on the sup to a Thor one as I was getting a code 42 & a red triangle. Once the thor was fitted, the tri-angle problem went away however the active spoiler never dropped @ 60mph. I got one of the tuners here to have a look at it and they noticed that the PINK cable that goes into the active spoiler ECU was disconnected (explaining the manual operation of the active spoiler before) - they re-connected this wire and the spoiler retracts @ 60mph as designed. - happy bunny OR I thought until I drove the car on the motorway and the red light came on @ 80-85 and the spoiler retracted itself at that speed. (code 42 again) Sometimes the spoiler doesnt come down itself @ 60mph either. When the car is parked the active spoiler operates fine (no obstructions or anything) And what even strange now is that if I disconnect the pink wire that goes into the active spoiler ECU, the speedo, ODO all stop working...... What could the problem be and how do I fix it? Link to comment Share on other sites More sharing options...
imi Posted February 18, 2006 Author Share Posted February 18, 2006 Any idea of that this could be..? Link to comment Share on other sites More sharing options...
secondjump Posted February 18, 2006 Share Posted February 18, 2006 Pink wire = 1st speed sensor signal wire. Check any joins for after market toys connected to this wire, there maybe a poor solder joint or dodgy taped connection. Link to comment Share on other sites More sharing options...
