Suprash Posted October 11, 2010 Share Posted October 11, 2010 Well I started the car the other day, she fired up fine, was running for a minute or so then just cut out and died I immediately tried to start her again and she was just cranking over and over. The fuel was a bit low so I got a jerry can and threw that in to make sure it wasnt fuel, still the same So next I started to go through everything, took off dizzy and all is clean inside, pulled one of the plugs and that looked ok, bit wet, but thats only from cranking it over, checked for a spark on the plug and check. Cracked off one of the banjo's on the fuel line and fuel was there. Checked all the plugs on the ECU side, and everything looked ok. Checked all the plugs for ignition on the engine side and everything looks ok. Basically its baffling the hell out of me !!! It started and ran for a minute and now it just wont go, its not even trying to with that cough, cough that slowly gets faster as each cycle burns, its like there is no spark or fuel but both look ok ? Am I missing something obvious ? Im literally out of ideas to check next ??? Link to comment Share on other sites More sharing options...
pistonbroke Posted October 11, 2010 Share Posted October 11, 2010 Flooded? Link to comment Share on other sites More sharing options...
Suprash Posted October 11, 2010 Author Share Posted October 11, 2010 Nah, its been left over a day before I tried again, and cranked it with my fuel pump fuse pulled........ What ever it is, is what killed it whilst it was running......? Link to comment Share on other sites More sharing options...
Swampy442 Posted October 11, 2010 Share Posted October 11, 2010 Fuel pump ECU? Cam/crank sensor? Link to comment Share on other sites More sharing options...
Suprash Posted October 11, 2010 Author Share Posted October 11, 2010 There is no fuel pump ECU, crank sensor ? Dunno, maybe ? Does that throw a code, guess I could check to see if any codes are stored but I cant remember how to do that bridge two ports thing, then switch your ignition on/off however many times to get the dash lights to flash any codes ?? Anyone remember ? Link to comment Share on other sites More sharing options...
JODY T Posted October 12, 2010 Share Posted October 12, 2010 (edited) there should be an oem fuel pump ecu behind the passenger rear boot plastics that you have removed.. its behind where the light would be on a standard car.. do you run a piggy back? ide remove it, and try and start it, sounds a bit like barny brendans car a while back.. he changed everything and couldnt find anything.. turned out that the piggy back wasnt sending the signal to create the spark.. although if i remember correctly he said it had a spark but not strong enough.. He removed the ecu and it fired straight away Just a thought Edited October 12, 2010 by JODY T (see edit history) Link to comment Share on other sites More sharing options...
JustGav Posted October 12, 2010 Share Posted October 12, 2010 Don't think you use the bridge port diag thing, on your standalone.... You checked the wires (you knew I was going to say that ) FPC has been well and truely removed Link to comment Share on other sites More sharing options...
JODY T Posted October 12, 2010 Share Posted October 12, 2010 ah standalone.. Scrap my idea then lol.. could be an ecu fault though? Link to comment Share on other sites More sharing options...
Suprash Posted October 12, 2010 Author Share Posted October 12, 2010 To be honest, that was my trail of thought the other night, ECU fault, because I have literally tried everything else, well, when I mean tried, I mean by non-mechanic skills, I bet Graham could come round like last time and 5 minutes - BANG !!!! Hey-presto Where is that Douche anyway......... Link to comment Share on other sites More sharing options...
scotty71 Posted October 12, 2010 Share Posted October 12, 2010 A guy posted on here a few months back with the same issue. Running fine and just cut out. Turned out to be in the end a loose wire on an ECU in the passenger footwell. Link to comment Share on other sites More sharing options...
Swampy442 Posted October 12, 2010 Share Posted October 12, 2010 Where is that Douche anyway......... Im sure he'll be happy to help you now Link to comment Share on other sites More sharing options...
Suprash Posted October 12, 2010 Author Share Posted October 12, 2010 A guy posted on here a few months back with the same issue. Running fine and just cut out. Turned out to be in the end a loose wire on an ECU in the passenger footwell. I'll go back and re-check all the ECU side Im sure he'll be happy to help you now He deserves it, last time he was round he managed to sweet talk my misses into making warm freshly baked cakes, I've been trying to do that for ages Link to comment Share on other sites More sharing options...
JustGav Posted October 12, 2010 Share Posted October 12, 2010 Where is that Douche anyway......... House-arrest by the missus I reckon Link to comment Share on other sites More sharing options...
Suprash Posted October 12, 2010 Author Share Posted October 12, 2010 House-arrest by the missus I reckon Tell him to man up, or maybe she wears the trousers and Graham likes to wear the naughty underwear Link to comment Share on other sites More sharing options...
