FlrSupra Posted August 26, 2010 Share Posted August 26, 2010 Bought new Supra and now found out my sidelights doesn`t work. To tell the story short I`ve found out I have following pieces to combine. My car is Facelift Supra with: - Pre-facelift UK headlights - Facelift indicators with empty sidelight pod, but the indicators are working. Last owner has made some own wiring to make front indicators work, but seem to have messed something up because there is no sidelights or fog lights working. Here are the pictures which will make sense to someone. http://gto.kuvat.fi/kuvat/parkki1.jpg/full http://gto.kuvat.fi/kuvat/parkki2.jpg/full http://gto.kuvat.fi/kuvat/parkki3.jpg/full So... which wires I should hunt down to make my sidelights work on facelift indicators? Link to comment Share on other sites More sharing options...
Nic Posted August 26, 2010 Share Posted August 26, 2010 This how to guide should help http://mkivsupra.net/vbb/showthread.php?t=31633 Link to comment Share on other sites More sharing options...
FlrSupra Posted August 27, 2010 Author Share Posted August 27, 2010 This how to guide should help http://mkivsupra.net/vbb/showthread.php?t=31633 Thanks for participating again, Nic. Otherwise that would be great guide, but my car is Facelift so I think I do not have same "power source" for sidelight that is there on the guide. Basically I just need information that which wire control the sidelight`s positive side on Facelift wires? Link to comment Share on other sites More sharing options...
FlrSupra Posted September 1, 2010 Author Share Posted September 1, 2010 This is now SOLVED! Some UK fella had tried to combine prefacelift-foglights to facelift-indicator loom (???????????) with bad result. Ripped all selfmade wiring and used simple method that Nic posted to wire indicators up. Perfect. Thanks again Nic! Link to comment Share on other sites More sharing options...
