Guest popes996 Posted July 18, 2010 Share Posted July 18, 2010 Hi there, found this forum while looking for some answers, and will be trawling the search function asap . I have gained a 1994 Mkiv twin turbo import through a mate, it's got a few mods (none of which I know much about) and a few problems (typical!!) Can I ask some advice? Is the Blitz SBC faulty if occasionally the unit clicks/knocks rapidly with the ignition on? (it also knocks occasionally while 'on boost' - not all the time). Sometimes the car feels 'quick', other times it seems to be holding back - plenty of boost, just no 'go' if you get where I'm coming from? (this may be relevant to the speed of applying the throttle? - Seems OK if the throttle is rolled on progressively) Set up of the Blitz boost ecu, does anyone have a manual? The unit doesn't have a model code on it but it has a fair few functions: Boost/Chassis dynamics/Pressures (Oil/fuel etc)/Temps (Oil/Coolant etc)/ AFR and lots more, the majority aren't used though - cheap install?? De-limit? The car cuts dramatically at 120 - just as it gets into it's stride!! First time I thought it had died, luckily not!! Does anyone know the car? A forum like this I would think someone knows someone who knows someone N534 NOU Quote Link to comment Share on other sites More sharing options...
scotty71 Posted July 24, 2010 Share Posted July 24, 2010 Welcome, too early in the morning to answer Q's Quote Link to comment Share on other sites More sharing options...
richarde7927 Posted July 24, 2010 Share Posted July 24, 2010 Hello and welcome to the forum . Rich. Quote Link to comment Share on other sites More sharing options...
