Rear Light cluster
C_Strike
for my MOT, which i failed:P
The rear light clusters do not match.
i need to exchange one of these rear light clusters to match the other side... not fussy whic as long as the replacement is in good condition as mine are.
Hers a pic to show why.
http://img261.imageshack.us/img261/5826/img8650l.jpg
Could do with meeting to exchange or something.
Possibly interested in buying one too if thats the only possibility.
regards
BTW...
Can these lights be opened and can the odd lights be swapped posiition to save me this problem?
The inner two lenses are a different size to the outer two lenses. It looks to me that you have an import passanger rear light, and a UK spec drivers side light. You can heat the lights up in an oven (there is a how to guide on here somewhere which i have used and is spot on) take them apart and change the order of the lenses just make sure the correct lights are the legal colour! Not sure on the wiring tho as the brake light is a twin element lamp therefore is a different lamp holder to the reversing light.
