w41k3r Posted June 16, 2010 Share Posted June 16, 2010 How do i tell what strength the wastegate spring is is it a case of just buying one you know the strength of or is there a way to tell? The one i have is a greeny brown colour i presume its an xs one but not sure im wanting one around 7psi any ideas Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 16, 2010 Share Posted June 16, 2010 i think the brown xs spring is 12 psi iirc the 7 psi spring is red Link to comment Share on other sites More sharing options...
w41k3r Posted June 16, 2010 Author Share Posted June 16, 2010 cheers mate also where do you measure to find out what size wastegate it is because the springs are for diff sizes Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 16, 2010 Share Posted June 16, 2010 pass? Link to comment Share on other sites More sharing options...
supspower Posted June 16, 2010 Share Posted June 16, 2010 So you have a spring but no wastegate? or do you have the wastegate and want to know what pressure this spring will be in that wastegate? Link to comment Share on other sites More sharing options...
w41k3r Posted June 16, 2010 Author Share Posted June 16, 2010 have both want to know how i can tell what size wastegate i have ie where i measure and how to test the strength thanks Link to comment Share on other sites More sharing options...
supspower Posted June 16, 2010 Share Posted June 16, 2010 measure the hole where the valve is ie where it bolts on to the manifold. To test the strength you can hook the wastegate up to a air compressor (one where you can control the pressure) and see at what pressure the gate opens. Link to comment Share on other sites More sharing options...
w41k3r Posted June 17, 2010 Author Share Posted June 17, 2010 This is the wastegate i have not had chance to measure it been busy sorry might be aable to guess lol Link to comment Share on other sites More sharing options...
