car not starting, fuel pump??
robsaxby
help guys, iv been out in car today, running fine, started perfect this morning, been home, went to go start it, and nothing, all my lights work, everything spins but just not firing, fuel pump problem? also wen the key is turned, the fuel pump doesnt prime and there is no noise from the pump itself, u knw the buzzing sound?
there is a hks fuel and ignition timing computor in the passenger footwell, not sure if it has been knocked
any help would be brilliant, cheers
Have a search, get a paperclip, open the engine bay diagnostic port insert the clip into the port FP and...... Im not sure of the other and I dont want to say maybe incase it wrecks something...
*edit, you do this to get round the fuel pump ECU, if its shagged the fuel pump wont run *
found it...... +B to FP connections of the diagnostic port on the engine (i.e. voltage fed to the pump all the time the ignition is on).
But Rob.. All the time this advice has been given its on a (do it on your own head basis) As swampy said. Dont shag up your nice TT 6spd matey :D
before you ask The diag port is on the front of intake plenum, it has should have diag written on it ;)
Edited by scotty71 (see edit history)
Only for testing though, don't run it full time this way, the diag wiring loom is not up to long term high current.
The FP diag port is for reading the voltage going to pump, not for supplying it.
with having power to the ECU/pump I think someone has caught the HKS gizmo in the footwell thus creating a loose connection. As you have just stated...check all the connections to the HKS so it is definate.. dont want it to conk out on you miles from home :D
