Glued Locks?
Sakey
How do you know if your locks have been glued? :(
Alot of cars around the area recently have either been broken into or had the locks glued. So i went to check and the key wont turn in passanger or driver side door barrels. On removing the key white powdery stuff comes out.
Boot opens fine!
I'm asking because i've never used the door locks (opens on the phob) so not sure if the barrels were seized before from lack of use.
