J-Spec decat pipes
RedT18
Hey guys,
I am new to the board and have a question concerning the front exhaust section.
My J-Spec supra is equipped with decat-pipes made from mild-steel.
Do oyu know where i can get new decat pipes in 3" and Stainless steel?
I only found 2,5" pipes or pipes for the UK-spec.
thx for your help!
1st decat: You need the correct one for a UK or J-Spec - they're NOT interchangeable because the stud holes are different.
2nd decat: Either pipe will physically fit both UK and J-Spec models, but on a UK model the 2nd cat has an O2 sensor, so you have to have a decat pipe with the gland for the sensor. You can use a UK 2nd decat pipe on a J-Spec if you block off the O2 gland with a plate - or you could use the gland for a sensor for an AFR gauge.
