L33 Posted March 11, 2010 Share Posted March 11, 2010 done a quick search and got a few answers... when doing a standing start if i put my foot down with trac off it wud only bounce up to 3k then eventually get goin....ive removed the trac fuse and now it pulls away a treat and now no i have a torsen diff not a normal one so thats a old thread covered thing is my manu button wont work and the OD flashes with the trac light obviously its because its picked up a fault and does flash as i searched but is it normal for the OD to flash and manu not to light up when it def did before? cheers Link to comment Share on other sites More sharing options...
L33 Posted March 11, 2010 Author Share Posted March 11, 2010 bumpski Link to comment Share on other sites More sharing options...
BOB B Posted March 11, 2010 Share Posted March 11, 2010 Hi mate, I have a problem with my traction and I have the trac light on 95% of the time, which is simillar to having the fuse out. I have an auto like you and my manu does not work, I have spent quite a long time going through lots of threads on the subject and it appears that if you have an auto you will not get manu if you disable or there is a fault with the trac. It also can effect the way the auto box changes the gears, ie harsher. I'm going to have to put mine in to get it looked at. Hope this is of help. Bob. Link to comment Share on other sites More sharing options...
L33 Posted March 11, 2010 Author Share Posted March 11, 2010 ok mate cheers, i have the boostlogic boc so used to harsher gear changes as long as its normal if this happens i will live with it cheers Link to comment Share on other sites More sharing options...
