AFR - mapping - Is this OK ?
Guest J O H N S O N
Guest J O H N S O N
Hey guys
I do not know quite whether it is necessary for me to have mapped my car ... What do you think ?
AFR meter shows 11.5-12.2 idling on hot engine
And around 10 at full throttle ... Is this too rich mixture - or I can run like that?
Guest J O H N S O N
My setup :
*Jun Rods
*Jun Pistons.
*HKS head gasket.
*HKS 280 cams
*HKS wastegate
*Greddy T88-34D turbo
*Koyo Radiator
*Greddy Oil cooler
*Greddy intercooler 3 row.
*Veilside intake manifold m/100mm
*Screamer pipe
*custom pipes(polish)
*Greddy cathtank
*Greddy cam gears
*Greddy timing belt
*Sard fuel rail(polish)
*1000cc injectors Denso
*Greddy manifold
*HKS f-con engine manegement.
*HKS trible plate clutch
*Twin external fuel pumps
*Greddy pulley kit
*HKS twin power dli II
*Sard fuel regulator
Idle should be 14.7:1
0.0-0.7bar ~12.5-11.7:1
0.7bar+ ~11.3-10.3
Cold idle will probably be in the 13's...
In short your AFR's are a mess and you need it sorting - you're threatening the engine with bore wash, oil contamination and detonation.
The AFR gauge probably stops as 10....but the real reading is far lower.
I would guess if it used to be ok that the fuel pressure is too high but I couldn't be sure without some facts...
Edited by Alex (see edit history)
My setup :
*Jun Rods
*Jun Pistons.
*HKS head gasket.
*HKS 280 cams
*HKS wastegate
*Koyo Radiator
*Greddy Oil cooler
*Screamer pipe
*Greddy cathtank
*Greddy cam gears
*Greddy timing belt
*Greddy manifold
*Greddy pulley kit
nice spec, you need to get it tuned correctly else you will kill the engine ...
Guest argy911
Sounds ok to me. Maybe a little rich on idle.
Sounds good to me too .you should up your boost .From what I know..:D
Hi Johnson, as I said before you're consistantly over rich in all areas of the map.
Are you able to get the static fuel pressure? You can get that without firing the engine if you have a gauge, there is a guide how to check it.
No idea how much driving you've done with the fueling like this but I promise you anymore is risking it's long term health.
Please take it to your nearest HKS mapper.
Guest J O H N S O N
Heh, I get a lot of different responses - some say it's ok - others says i cant run the car :/
You Should take your Beast to shakspeare raceway;)
What planet are you on - sod off out of technical if you're going to make silly comments like that.
Seriously.
The last thing anyone should do is encourage driving this car in this state.
Pick up a copy of ANY tuning book, like Maximum Boost by Corky Bell
http://www.amazon.co.uk/Maximum-Boost-Turbocharger-Engineering-Performance/dp/0837601606
and it will confirm what I am saying. It's worth reading a book like that when you own a modified turbo car so that you know what's what with your pride and joy!!
