jackso11 Posted October 27, 2009 Share Posted October 27, 2009 Can you get these wheels with an offset of 35, or are they all 30? If anyone knows anywhere i can get a set with a better fitting offset than 30 please let me know, otherwise I will have to have my arches rolled Link to comment Share on other sites More sharing options...
supspower Posted October 27, 2009 Share Posted October 27, 2009 Fronts will be fine, if you run 255's on the back you shouldnt need to roll the arches just be careful going over bumps at speed!! Link to comment Share on other sites More sharing options...
dandan Posted October 27, 2009 Share Posted October 27, 2009 My fronts are 35 (8.5" wide with a 245 40 18) and the rears are 30 (9.5" wide with a 275 35 18). No arch rolling here but my suspension is pretty hard. When I change to CW's suspension setup I will likely need to roll/trim the rear arches. Link to comment Share on other sites More sharing options...
jackso11 Posted October 27, 2009 Author Share Posted October 27, 2009 when you trim arches, where do they actually trim? does the car look different from the outside or is it just the inside of the arch that is changed? Total novice when it comes to trimming/rolling arches. Link to comment Share on other sites More sharing options...
heckler Posted October 27, 2009 Share Posted October 27, 2009 when you trim arches, where do they actually trim? does the car look different from the outside or is it just the inside of the arch that is changed? Total novice when it comes to trimming/rolling arches. its just the inside lip... looks no different from the outside -and yes, I have the GTR's too and the lips needed trimming Link to comment Share on other sites More sharing options...
jackso11 Posted October 27, 2009 Author Share Posted October 27, 2009 what happens to the inside lining? The plastic bit? does that not fit anymore or does it need modifying in some way? Link to comment Share on other sites More sharing options...
supspower Posted October 27, 2009 Share Posted October 27, 2009 To the best of my little knowledge.... Its the lip on the arches they either bend it back or cut it off slightly. There are possible side effects if it doesnt go 100% think some people have had the "50p" effect when rolled?? and also arches are prone to rust if the paint cracks while rolling, or where the lip has been trimmed...just treat with rust proof stuff. Best bet is to get them trimmed... to avoid damage to the shape of the arch Doent look different on the outside unless you get the arches flared.... Link to comment Share on other sites More sharing options...
supspower Posted October 27, 2009 Share Posted October 27, 2009 The plastic bit on the fronts? Link to comment Share on other sites More sharing options...
jackso11 Posted October 27, 2009 Author Share Posted October 27, 2009 Ah, thanks for that. Plastic bit as in the lining of the arch. Link to comment Share on other sites More sharing options...
heckler Posted October 27, 2009 Share Posted October 27, 2009 what happens to the inside lining? The plastic bit? does that not fit anymore or does it need modifying in some way? plastic part (as already mentioned) is front only. Only the rears need trimming/rolling Link to comment Share on other sites More sharing options...
jackso11 Posted October 27, 2009 Author Share Posted October 27, 2009 yeah, just realised there is no plastic liner on the rear doh. Link to comment Share on other sites More sharing options...
dandan Posted October 27, 2009 Share Posted October 27, 2009 plastic part (as already mentioned) is front only. Only the rears need trimming/rolling How much did you trim off, can you remember? 6, 8, 10mm? Does that now give you a full range of motion at the rear allowing the tyre to rise up into the arch? Link to comment Share on other sites More sharing options...
heckler Posted October 27, 2009 Share Posted October 27, 2009 How much did you trim off, can you remember? 6, 8, 10mm? Does that now give you a full range of motion at the rear allowing the tyre to rise up into the arch? I "think" it was arround 10mm (i didnt trim it) - but yes, now have full movement Link to comment Share on other sites More sharing options...
LOGIE Posted October 30, 2009 Share Posted October 30, 2009 is this normal for all 18" wheels? Link to comment Share on other sites More sharing options...
jackso11 Posted October 30, 2009 Author Share Posted October 30, 2009 no, its notmal for an offset of 30. 35 and up and you don't need it doing. Upto 50 (which is standard). Link to comment Share on other sites More sharing options...
miko_supra Posted October 30, 2009 Share Posted October 30, 2009 Just ordered the tyres for my GTR's (265 on the rear) so should have them fitted on the car sometime next week. I will let you know how the fitment is. Link to comment Share on other sites More sharing options...
