Scott Posted September 13, 2009 Share Posted September 13, 2009 At the moment the taps & waste of my bath is at the far end from the wall. Is it a simple enough job to move these to the middle so that i can have a double ended bath? Would it involve ripping up the floor boards or do i just put in some extensions? Having a look at bathroom suites and i just want to know what can and can't be done easily. Thanks Nevermind, Wife says no lol. Might have other query's later so might as well leave this open for now though. Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted September 13, 2009 Share Posted September 13, 2009 the only problem i have ever come across is the taps being in the centre of the bath if you ever have a problem or want to change them its a biggish job as with some baths you can't just reach under with the tap spanner unless you wave megga long bendy arms ...... Link to comment Share on other sites More sharing options...
RobSheffield Posted September 13, 2009 Share Posted September 13, 2009 Plumbing Link to comment Share on other sites More sharing options...
Ewen Posted September 13, 2009 Share Posted September 13, 2009 Stay with the taps at one end. You can top-up with your toes when on your own, and it gives the misses something to hang on to and stop sliding about when you are not. Link to comment Share on other sites More sharing options...
Scott Posted September 13, 2009 Author Share Posted September 13, 2009 Plumbing LMAO, yeah that! Stay with the taps at one end. You can top-up with your toes when on your own, and it gives the misses something to hang on to and stop sliding about when you are not. Hmm, she said the same thing. Link to comment Share on other sites More sharing options...
Jamesy W Posted September 13, 2009 Share Posted September 13, 2009 Flexi tap connectors are a wonderfull invention Although if you ever had to replace them it would mean probably having to take out the bath, but seeing as you are about 8 ft tall, you could probably reach under no hastle The waste should be no problems either Link to comment Share on other sites More sharing options...
Scott Posted September 13, 2009 Author Share Posted September 13, 2009 Flexi tap connectors are a wonderfull invention Although if you ever had to replace them it would mean probably having to take out the bath, but seeing as you are about 8 ft tall, you could probably reach under no hastle The waste should be no problems either That sounds like just the chaps regardless bud. I have a feeling you will be here for "emotional" support anyway Just going to go with conventional end taps that we have just now. Still, i doubt it will be exactly the same as what we have just now anyway. How much hassle is it sorting out the mixer's? The taps the mrs wants are both mixers, we have seperate ones just now. Link to comment Share on other sites More sharing options...
Jamesy W Posted September 13, 2009 Share Posted September 13, 2009 IT's a peice of p!ss mate. It's still two connections on the underside. Just let me know when, so I can have my crack waxed. Link to comment Share on other sites More sharing options...
