hadyn Posted August 30, 2009 Share Posted August 30, 2009 What temperature does the TT coolant run as stock when at operating temp (ie when the needle is in the middle of the stock water temp gauge) ? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 30, 2009 Share Posted August 30, 2009 The std gauge is not very sensitive and seems to stay in the middle position anywhere between 90c and 110c, my average seem to be around 98c to 105c, and a little higher when i was TT. Link to comment Share on other sites More sharing options...
hadyn Posted August 30, 2009 Author Share Posted August 30, 2009 Im more interested in the temp that is coming out of the head into the heater matrix - anyone know? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 30, 2009 Share Posted August 30, 2009 It will be pretty much the same as whats coming from the top rad hose which is where both std sensors are and my thermocouple, for good reason;) Link to comment Share on other sites More sharing options...
Bossco Posted August 31, 2009 Share Posted August 31, 2009 I'd agree with those temps. I did hit 115 degrees a few months back with the standard gague staying exactly where it usually does. After binning the stock rad and fitting a big alli one, replacing the thermostat, fitting new fan (Cheers Hodge:d) I've not been able to get the temp above 102 degrees. Fingers corssed it stays that way cos I've not been able to use the car this summer. Link to comment Share on other sites More sharing options...
hodge Posted August 31, 2009 Share Posted August 31, 2009 I'd agree with those temps. I did hit 115 degrees a few months back with the standard gague staying exactly where it usually does. After binning the stock rad and fitting a big alli one, replacing the thermostat, fitting new fan (Cheers Hodge:d) I've not been able to get the temp above 102 degrees. Fingers corssed it stays that way cos I've not been able to use the car this summer. And a water pump LOL. No probe at all mater glad to help. Link to comment Share on other sites More sharing options...
