bodilx6 Posted August 22, 2009 Share Posted August 22, 2009 (edited) anything else than : split vacuum line blown 2nd turbo VSV failure Car is completely decatted and a 50mm RR fittet where the 2nd cat used to be. I've been searching, just needed an assurance and clear answer since other posts can be a bit "this and that". Edited August 22, 2009 by bodilx6 (see edit history) Link to comment Share on other sites More sharing options...
hoff Posted August 22, 2009 Share Posted August 22, 2009 Need a bit more info really. Do you have boost gauge giving you a reading? If so, what is it? Also what are the engine mods you have carried out? Any strange behaviour/noises? Give as much info as you can and I'm sure somebody can help (not me though, it goes in one ear and out the other:D). Link to comment Share on other sites More sharing options...
bodilx6 Posted August 22, 2009 Author Share Posted August 22, 2009 only mods are: 2.5" full exchaust, HKS BCC, about to add an HKS SLD and the 50mm RR at the 2nd cats place. Thats it. No apparent noises, fine vacuum at -0.6-0.7 bar at idle. only boosts 0.9 bar Link to comment Share on other sites More sharing options...
R Black Posted August 23, 2009 Share Posted August 23, 2009 Do you need a RR, won't the 2nd cat do the job of the RR. Link to comment Share on other sites More sharing options...
Supradan Posted August 23, 2009 Share Posted August 23, 2009 If you are running with the cats in then 0.9Bar sounds spoton. If you are running without cats and no r/r then you are a bit silly!! Link to comment Share on other sites More sharing options...
Stephendjb Posted August 23, 2009 Share Posted August 23, 2009 Have you not put a boost controller on it? Link to comment Share on other sites More sharing options...
ellis Posted August 23, 2009 Share Posted August 23, 2009 No FCD? Link to comment Share on other sites More sharing options...
ellis Posted August 23, 2009 Share Posted August 23, 2009 If you are running with the cats in then 0.9Bar sounds spoton. If you are running without cats and no r/r then you are a bit silly!! First post - decatted! Link to comment Share on other sites More sharing options...
Stephendjb Posted August 23, 2009 Share Posted August 23, 2009 HKS BCC fcd Link to comment Share on other sites More sharing options...
Guest Dante Posted August 23, 2009 Share Posted August 23, 2009 This is quite funny. I have EXACTLY the same "problem". Full decat WITH RR, bcc and all the BPU parts. But I don't get more than 0,9bar boost either. It should be around 1.2bar with this BPU spec even without the help of a boost controller? My Supra is even TTC mode. Atleast if you read through the BPU post in the FAQ. Link to comment Share on other sites More sharing options...
Stephendjb Posted August 23, 2009 Share Posted August 23, 2009 My Aristo was only boosting to 0.8 bar with full BPU mods except a boost controller & runs 0.9 bar in ttc mode without a boost controller Link to comment Share on other sites More sharing options...
BOB B Posted August 23, 2009 Share Posted August 23, 2009 fcd As above, if you havn't got a "fuel cut defencer" fitted your fuel supply is cut as the car approaches 1 bar by your ECU, read up in tech info about fcd. Bob Link to comment Share on other sites More sharing options...
pete_TT Posted August 23, 2009 Share Posted August 23, 2009 Mine does this sometimes. some of the time i get normal boost, though at other times it only boosts to 0.9 bar Link to comment Share on other sites More sharing options...
Scott Posted August 23, 2009 Share Posted August 23, 2009 0.9 here too, no idea why. I asked ages ago but got nowhere. Link to comment Share on other sites More sharing options...
Stephendjb Posted August 23, 2009 Share Posted August 23, 2009 As above, if you havn't got a "fuel cut defencer" fitted your fuel supply is cut as the car approaches 1 bar by your ECU, read up in tech info about fcd. Bob he has a HKS BCC boost cut controller same thing as a FCD Link to comment Share on other sites More sharing options...
jaymdee Posted August 23, 2009 Share Posted August 23, 2009 anything else than : split vacuum line blown 2nd turbo VSV failure Car is completely decatted and a 50mm RR fittet where the 2nd cat used to be. I've been searching, just needed an assurance and clear answer since other posts can be a bit "this and that". I'd take the RR out and have the apperture widened to 54mm (ie take 2mm off all round). All cars are slightly different and won't all boost to the same levels with BPU mods Link to comment Share on other sites More sharing options...
trinitom Posted August 24, 2009 Share Posted August 24, 2009 i think 50mm RR in an 2,5" exhaust you will never get more then that without a boost controller! I'm running 54mm RR in 3" exhaust and I'm getting 1.08 bar, previously i had an 56mm RR and producing 1.2 bar, on cold days 1.3, 1.4 bar. Link to comment Share on other sites More sharing options...
bodilx6 Posted August 24, 2009 Author Share Posted August 24, 2009 I'd take the RR out and have the apperture widened to 54mm (ie take 2mm off all round). All cars are slightly different and won't all boost to the same levels with BPU mods i think 50mm RR in an 2,5" exhaust you will never get more then that without a boost controller! I'm running 54mm RR in 3" exhaust and I'm getting 1.08 bar, previously i had an 56mm RR and producing 1.2 bar, on cold days 1.3, 1.4 bar. I've come to the same conclusion. When it got a bit colder and after tightening the different hoses we ended up with 1 bar of boost. So 2.5" + the RR must be the reason. Well, 1 bar is also good then a BC will have to add the rest Link to comment Share on other sites More sharing options...
