themodifiedkid Posted July 1, 2009 Share Posted July 1, 2009 Right, I fitted an uprated fuel pump and now have noticed that the fuel gauge doesn't go below 1/4 tank, even when the fuel light comes on. So Im guessing i have probably bent the arm of the sensor (the one that acts as a type of float valve) as i was taking out or putting back into the tank. SSOOOOOOO i was wandering if anyone had a picture of the above mentioned float valve(sensor arm) in its natural position so I can bend it back to its right position Thanks everyone:D:D:D:D:D:D Link to comment Share on other sites More sharing options...
nigelboyne Posted July 1, 2009 Share Posted July 1, 2009 did the same thing filled it to the brim drove hundred miles needle stuck at full position Link to comment Share on other sites More sharing options...
themodifiedkid Posted July 1, 2009 Author Share Posted July 1, 2009 did the same thing filled it to the brim drove hundred miles needle stuck at full position Did you end up bending the arm back? How did you fix it? Link to comment Share on other sites More sharing options...
nigelboyne Posted July 1, 2009 Share Posted July 1, 2009 i need a solution to just happened today Link to comment Share on other sites More sharing options...
themodifiedkid Posted July 5, 2009 Author Share Posted July 5, 2009 BUMP. Again does anybody have a picture of the stock fuel pump hanger with everything attached so i can see the position of the fuel guage (float valve) Thankyou Link to comment Share on other sites More sharing options...
themodifiedkid Posted July 5, 2009 Author Share Posted July 5, 2009 Ive managed to source this now, spent a bit more time searching on here Link to comment Share on other sites More sharing options...
