TT j spec engine
L33
i have a j spec tt engine for sale, bought this about a year ago but its been sat in a garage since and not fitted.
as you can see there is slight damage but nothing serious.
ive tried to show the damage as best as i can, the cam pullys are NOT damaged, the big tensioner on the left hand side is a little buckled but again its only a bolt on part
will sell all of the below, with turbo pipes, and intake manifold, BUT NO turbos or throttle body, as you can see the electrics have been cut out but coil packs are still there
i was told this was compression tested fine, and was from a car below 30k miles but there is NO proof of this so its up to you if you want to do your own test. the mechanics that this has been stored at thinks it looks like a good tidy engine
im looking for £700 for the lot collection only
07891039955
cheers
Ut o....looks like its from an aristo as the sump is back to front and the PAS pump is in the wrong place :search:
Lots of things look weird on it like the engine mounts,sump,Pas pump,Waterpump etc...
What does the engine code say on the block? Its on the Nearside in front of the engine mount.
Do you know if there are any other differences to make this as a long Motor fit a Supra?
Are the cams, Displacement, Head and Block castings,Crank damper,belt tensioner all the same and fully compatible?
Obviously the wiring harness,engine mounts and feet and all the anciallirries are completely non compatible.
Hi stu, hope some one can give you this info, as you know my mechanical understandings are poor. Obviously this not being a supra engine i will now take 500 collected
it is a supra engine! lol the sump just needs to be swapped. ow well, good luck with sale, im selling one to :)
