upgradeing to facelift dash panel and cluster
supramemole
Hey everyone. Was wondering if anybody out there has updated their preface lift dash trims and cluster with the facelift or S2 panels and cluster. I have the 1993 NA/Auto and want to upgrade the trim pieces and cluster with the facelift one and was wondering if I have to change out all the wiring. Under dash or if the harness will plug right into the S2 cluster? Thanks again for any help out there.
Chris
Guest gtjames
i havent never done this but you would have to change the harness as facelift have the battery or turbo depending if tt or not and water temp and fuel gauge in the main cluster and facelift is an anologe odo and pre face lift is digital it would be a lot of hassel
Won't just plug straight in, it is do-able to rewire it to suit, would I, hell no!
Yep, looking into this before and it is possible, but would be a wiring nightmare, not a job for the faint hearted.
  • 1 month later...
Guest artbran
I'm also wanting to do this.. Does anyone have any links I can look at for idea's/diagrams and so on?
I have an import front clip from japan that I will be using for the parts to rebuild my theft recovery supra that I just purchased. Since it has the newer gauges, I would like to use them in the rebuild.
My only issue is that the under dash harness has been cut a bit. The wires that went to the radio, and the 2 climate control boxes above it are cut. (79 total wires... Haha)
My plan is to use the JDM ECU (for now) along with everything else along with converting the speedo to MPH.
This is a project for the next 6 months so if anyone can help me, that would be great.
