Tricky-Ricky Posted May 27, 2009 Share Posted May 27, 2009 Which wire would that be though? I tought the SP1 that I had tapped in to was from going in to the ECU? Is there another that I should have tapped in to? I'm using SP1 but i am J spec, there is an SP2 on the UK. Link to comment Share on other sites More sharing options...
ADL Mark Posted May 27, 2009 Share Posted May 27, 2009 Hmm, just had another look at the ECU pinouts for the UK/US car, the SP1 wire is on the E10 loom (the single plug on the ECU) whereas SP2 has a positive and negative connection and is in the E9 loom (the double plug with a bolt on the ECU). Link to comment Share on other sites More sharing options...
