suspension
fizzle
on the website it says they are gas adjustable, does this mean i gan lower them? also they only list for a turbo model so are these wrong to put on n/a?
TT springs are higher rate than NA because they are heavier up front. TT springs shouldn't be put on an NA as a result.
I believe the gas adjustable feature you're referring to is for the dampener, not the spring rate/ride height. Drop Bignum a PM to be sure?
