IT bods...
b_have
Hey guys, Having a pc problem and being a total IT numpty, need some help.
Bought a used pc (from a member) which was working fine until I installed AVG 8.5. When I restarted it comes up with an error ox80004005 "problem is preventing windows accurately checking validation licence"
The only way to get to my desktop is in safe mode. The computer didn't come with an installation CD :(
Any ideas? Should I try to un-install AVG?
hey bud, install error, are you using a genuine windows copy and key?
go in in safemode, and do a system restore
START>ALL PROGRAMS>ACCESORIES>SYSTEM TOOLS> SYSTEM RESTORE, RESTORE IT TO BEFORE AVG
Don't know if its genuine,(I am guessing not as there is was no CD with it) Would a sytem restore be better than un-install avg?
Don't know if its genuine' date='(I am guessing not as there is was no CD with it) Would a sytem restore be better than un-install avg?[/quote']
the error you have got then is related to the windows key. only way round that is a reformat unless you can sneak your way in with a key hack.
i got cds if u want one but there not genuine, have u got your own key?
Hi Charlie, Would it not be worth trying to remove AVG in safe mode?
If you do find it needs wiping and a new OS installing, am happy to provide what you need or give you a hand mate
Many thanks Christian, Ken (Ivan) is local to me and kindly offered to take a look. If we get stuck, will give you a call. :)
Ok heres a few simple things you can try if none of the above works. It seems that your OS isnt recognising that XP is a proper copy on your computer.
Use Start- Run and enter the following text in the dialog box:
regsvr32.exe regwizc.dll
Then do it again with the following text:
regsvr32.exe licdll.dll
Launch activation manually:
%SYSTEMROOT%\system32\oobe\msoobe.exe /A
Or you can try this
Try running the validation tool
http://www.microsoft.com/resources/howtotell/uk/windows/default.mspx
or
Run: "sfc /scannow" command
Reboot
