Robert Posted April 3, 2005 Share Posted April 3, 2005 Hi guys, i'm having a problem with the idle on my car since i got the car back from the bodyshop. The problem is when i start the car it will idle at around 1000 rpm for about a 30 seconds then it will slowly drop all the way to abut 500-550rpm. It sounds like the car is going to die, and twice has. I have a brand new battery and i've done a mini service by changing all the fluids and oil filter. I've also reset the ECU and still no good. Any idea's? i dont feel comfortable driving the car with the way it is currently thats why i cant get to a garage. Link to comment Share on other sites More sharing options...
neilg Posted April 3, 2005 Share Posted April 3, 2005 Has the car been stood a long time? Whilst mine was garaged, it did the same thing. Kept cutting out every so often without warning. Doing like yours too high idle when starting which would then drop. Thats probably a automatic choke though. My cutting out problem completly stopped when i put a fresh tank of fuel in the car. I therefore put it down to my petrol going off while stood. Give it a try if your car has been stood, if not i have no idea im affraid Hope you sort it Link to comment Share on other sites More sharing options...
Robert Posted April 3, 2005 Author Share Posted April 3, 2005 Yup the car has been standing for about 4 months, When i collected the car it was empty so i had to get a 10 litre can an fill the car with that but apart from that i haven't added any more petrol. Link to comment Share on other sites More sharing options...
neilg Posted April 3, 2005 Share Posted April 3, 2005 give it a try mate, i put £30 of bp ultimate in and it now seems fine. I had optimax left in it over the winter while it was stood. Been told befor eit goes bad pretty fast if you dont use it Link to comment Share on other sites More sharing options...
Robert Posted April 3, 2005 Author Share Posted April 3, 2005 its just getting to a petrol station that is the problem. I just took the car for a quick drive(about 200 meters) and parked it back now its revving at 450rpm in P. The revs stayed at 550 for about 3 mins then went down to 450rpm, i decided to park it back at home before it drops any lower. Link to comment Share on other sites More sharing options...
Robert Posted April 3, 2005 Author Share Posted April 3, 2005 by the way i forgot to say the car is a 93 jap auto TT Link to comment Share on other sites More sharing options...
neilg Posted April 3, 2005 Share Posted April 3, 2005 doh, sorry, mine is a manual, i could just keep dipping the clutch and blipping the accelerator to stop it stalling. Try get a big jerry can and do a couple of trips Link to comment Share on other sites More sharing options...
Robert Posted April 3, 2005 Author Share Posted April 3, 2005 i thought it might have something to do with the IACV because when i got the car back the engine bay was a complete mess,covered with all sorts of rubbish and dust from the bodyshop. Ive cleaned it up the best i can, but still the same problem. Link to comment Share on other sites More sharing options...
Robert Posted April 3, 2005 Author Share Posted April 3, 2005 cheers for the info guys.......i mean neil Link to comment Share on other sites More sharing options...
neilg Posted April 3, 2005 Share Posted April 3, 2005 Im sure somone will crop up soon and give you a propper answer and not just my waffle Link to comment Share on other sites More sharing options...
mr keef Posted April 3, 2005 Share Posted April 3, 2005 mines just started to idle high at around 2,then if i blip the throttle it goes to where it should be,but as soon as i start driving it goes back up to 2.I tried the ecu reset with no luck.any ideas? Link to comment Share on other sites More sharing options...
stt Posted April 3, 2005 Share Posted April 3, 2005 Could be a hos4e off somewhere,have a goosey round the plenhum chamber?? Link to comment Share on other sites More sharing options...
Robert Posted April 3, 2005 Author Share Posted April 3, 2005 Could be a hos4e off somewhere,have a goosey round the plenhum chamber?? i'll have a good look around there tomorrow, i doubt a hose is off though i would have noticed. Link to comment Share on other sites More sharing options...
Ian C Posted April 4, 2005 Share Posted April 4, 2005 You'd be suprised. Check especially the MAP sensor hose and anything t'd off it. If you need to get to a petrol station, try taking the PAS valve bypass hose off the intake plenum (its the hose nearest the PAS reservoir) so that some air bypasses the throttle and raises the idle. (note - doesn't work with MAF based cars). -Ian Link to comment Share on other sites More sharing options...
Robert Posted April 4, 2005 Author Share Posted April 4, 2005 Thanks Ian i'll have a good look around right now Link to comment Share on other sites More sharing options...
Robert Posted April 4, 2005 Author Share Posted April 4, 2005 ok, i've got an update on things, it seems as though the intercooler hoses weren't fitted properly and were loose so ive sorted the upper parts of the hoses out,i will check the lower parts of the hoses tomorrow when i take the battery out and change the rusty connectors. The main thing that confused me was that when i turned on the AC the revs didnt go up, the AC works fine but usually the revs would go up, maybe thats a clue to the problems im having? Link to comment Share on other sites More sharing options...
dude Posted April 4, 2005 Share Posted April 4, 2005 ok, i've got an update on things, it seems as though the intercooler hoses weren't fitted properly and were loose so ive sorted the upper parts of the hoses out,i will check the lower parts of the hoses tomorrow when i take the battery out and change the rusty connectors. The main thing that confused me was that when i turned on the AC the revs didnt go up, the AC works fine but usually the revs would go up, maybe thats a clue to the problems im having? Dude it really sounds like you need to get the car checked out properly , you seem to be having a lot of little problems , maybe theres a bigger one lurking . Dude :littled: Link to comment Share on other sites More sharing options...
Robert Posted April 4, 2005 Author Share Posted April 4, 2005 well unless i get the car towed to a garage, i dont really feel comforable driving it when i know there some kind of problem. Then theres the big question of what garage. Link to comment Share on other sites More sharing options...
Ian C Posted April 4, 2005 Share Posted April 4, 2005 ok, i've got an update on things, it seems as though the intercooler hoses weren't fitted properly and were loose so ive sorted the upper parts of the hoses out,i will check the lower parts of the hoses tomorrow when i take the battery out and change the rusty connectors. The main thing that confused me was that when i turned on the AC the revs didnt go up, the AC works fine but usually the revs would go up, maybe thats a clue to the problems im having? Normally the idle control valve cracks open a bit and lets on more air to up the idle. If you've got a mirror you can take the air feed hose off the ICV and use the mirror to watch the plunger. If it moves and the idle changes, it's working. If you have taken it off, don't forget to check the state of the one way valve it feeds in the intake manifold. If it's MAP based, btw, loose intercooler hoses wouldn't make jack all difference to the idle speed The MAP sensor measures the air in the manifold itself so air leaks increase the speed of the engine as it bypasses the throttle plate, feeds the engine more air and it gets metered and fed with the right amount of fuel. It's MAF based cars that underfuel and end up with a rough idle with air leaks. -Ian Link to comment Share on other sites More sharing options...
Robert Posted April 4, 2005 Author Share Posted April 4, 2005 Thanks for the information Ian, i'll get a mirror out and have a good look tomorrow, hopefully i can get to the bottom of this Link to comment Share on other sites More sharing options...
