Rob Posted April 3, 2005 Share Posted April 3, 2005 Aggghhhh. My supra's been parked up for two weeks, with the fuel injector fuse removed for safety. When I've just tried to start it, all I get is a very loud and quick ticking noise. What's happened? I've got fuel in the tank and it started fine two weeks ago, battery is fine as well. Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted April 3, 2005 Share Posted April 3, 2005 Sounds like the starter motor Link to comment Share on other sites More sharing options...
RobSheffield Posted April 3, 2005 Share Posted April 3, 2005 try putting it in gear (if manual) and rocking back and forth. sounds like the starter pinion is not engaging. the click you describe will possibly be the solenoid firing. Link to comment Share on other sites More sharing options...
tobyg Posted April 3, 2005 Share Posted April 3, 2005 had to charge the battery, last week with similar symptoms, after 2 weeks not running Link to comment Share on other sites More sharing options...
Rob Posted April 3, 2005 Author Share Posted April 3, 2005 It might actually be the battery, the windows barely opened, and when I checked the receipt it was over 6 years old. Oops. Link to comment Share on other sites More sharing options...
absz Posted April 3, 2005 Share Posted April 3, 2005 yeah defo flat battery mate, the ticking noise is the starter trying to engage but not enough current to do so Link to comment Share on other sites More sharing options...
Paul Posted April 3, 2005 Share Posted April 3, 2005 Yep, battery. I only left mine for a week and it drained it totally and that's with an 18mth old battery. Had the same symptoms as you before though, recharge sorted it. Paul Link to comment Share on other sites More sharing options...
