facelift clock
wilkorangerover
Probably not plugged in. Does it light up when you put the lights on? If not i'd say the dash has been off and they have forgotten to wire it back in. Due to the hassle of taking it all of again, they probably left it.
can you repair these clocks?
I would just take to bits and see if you can spot anything that doesn't look right.
Check first though that it's receiving a constant 12v supply, this is of course independent of the 12v supply required for illumination.
