Fibreglass Primer
Dnk
I thought etch primer was designed to go over bare metal?
It is as far as im aware as it eats into the bare metal so if put on paint it reacts, the young lad who primed up my bumper while i was out used etch primer and its reacted in places and softend the base coat.
Thats why ive had to flat it completely back to the gelcoat, all the black base coat as i rubbed with 180 grit rolled off rather than dust.
Thought it might be a problem, its designed to form a chemical bond with the substrate IE metal, it does exactly what the name implies, normal 2K should be absolutely fine, i have painted a fair bit of fibreglass and its always been fine.
What 2k ? i mean whos make do you use and i'll get some, would max meyer high build primer be any good ?
