gaz1 Posted January 25, 2009 Share Posted January 25, 2009 a complete list of the suspention bushes needed for the manual tt, i will be starting my new project in a week or so and want to start of with making the car feel like new to drive:D part numbers would be great too, i did search too:D Quote Link to comment Share on other sites More sharing options...
AlanM Posted January 25, 2009 Share Posted January 25, 2009 Nic had a list of these posted at one time, can't remember the thread though Quote Link to comment Share on other sites More sharing options...
gaz1 Posted January 25, 2009 Author Share Posted January 25, 2009 Nic had a list of these posted at one time, can't remember the thread though thanks will have a look;) Quote Link to comment Share on other sites More sharing options...
gaz1 Posted January 25, 2009 Author Share Posted January 25, 2009 thanks jon (pig) all sorted now:D Quote Link to comment Share on other sites More sharing options...
Pig Posted January 25, 2009 Share Posted January 25, 2009 Front ----- Upper: 48610-19025 Front Upper Arm - RH 48630-19025 Front Upper Arm - LH 48610G Nut for front upper suspension arm RH 48630C Nut for front upper suspension arm LH 4*90209 14007 std part, washer 48610F Bolt for front upper suspension arm RH 48630B Bolt for front upper suspension arm LH Lower: 48068-14080 Front Lower Arm sub assy - RH 48069-14080 Front Lower Arm sub assy - LH 43330L Nut, castle for front lower ball joint RH - does this come with sub assy? 43340B Nut, castle for front lower ball joint LH - does this come with sub assy? 2* 90468 16016 std part, castle nut binder - does this come with sub assy? 2* 48068G Nut for front suspension lower arm RH 2* 48069C Nut for front suspension lower arm LH 4* 90201 16017 std part, washer 2* 48194D Cam, front suspension camber adjust No2 RH 2* 48198D Cam, front suspension camber adjust No2 LH 2* 48657A Stopper, front lower arm bush 2* 48194C Cam, front suspension camber adjust No1 RH 2* 48198C Cam, front suspension camber adjust No1 LH 2* 95622 11200 std part, washer 2* 90170 12036 std part, nut Rear ---- 8* 90201 14020 washer, std part Lower arm (rearmost): 48730-14040 Rear Lower Arm - RH 48740-14070 Rear Lower Arm - LH 2* 48710P Nut, No2 rear lower control arm 2* 48710N Nut, No1 rear lower control arm 48194H Cam, rear suspension camber adjust No2 RH 48198R Cam, rear suspension camber adjust No2 LH 2* 48198H Cam, camber adjust, No2 Lower arm (frontmost): 48710-14110 Rear Arm Assembly RH 48720-xxxxx Rear Arm Assembly LH 2* 90179 12027 std part, nut 2* 48710N Nut, No1 rear lower control arm 2* 48198H Cam, camber adjust, No2 48194G Cam, rear suspension camber adjust, No1 RH 48198G Cam, rear suspension camber adjust, No1 LH Strut rod: 48780A Rod assy, rear 48780A Rod assy, rear 4* 48780C Nut for strut rod 4* 48780B Bolt for strut rod 48725-14070 Bush, rear axle carrier 48725F RH 48725-14070 Bush, rear axle carrier 48725G LH Upper arm: 48770A Arm assy, Upper control, rear RH 48790 Arm assy, Upper control, rear LH 4* 48770D Nut for rear upper control arm 2* 90201 14031 std part, washer 2* 48770F Ring, E for rear upper control arm 2* 48757 Attachment, rear suspension arm 2* 48770H Bolt, rear upper control arm RH 2* 48790B Bolt, rear upper control arm LH Quote Link to comment Share on other sites More sharing options...
