AdzC Posted January 14, 2009 Share Posted January 14, 2009 Hi all, I've done some searches but still not sure what to do regarding this. My radiator is always full to the brim with coolant but whenever I look at the expansion tank between the bumper and radiator it is always empty. I would just like to know if I should put some 4Life which I have into the expansion tank, half or full or just leave it as it appears normal. Assistance appreciated Regards Link to comment Share on other sites More sharing options...
SteveR Posted January 14, 2009 Share Posted January 14, 2009 Both the Supras I've owned have their expansion tanks elsewhere (towards the passenger side next to the battery), but they are marked with "MAX" & "MIN" levels - isn't yours? Link to comment Share on other sites More sharing options...
AdzC Posted January 14, 2009 Author Share Posted January 14, 2009 The one in the gap in front of the radiator? It's a clear plastic container with pipes going into it. Link to comment Share on other sites More sharing options...
Dnk Posted January 14, 2009 Share Posted January 14, 2009 Is it empty when its cold, it should be approximately half full. Link to comment Share on other sites More sharing options...
AdzC Posted January 14, 2009 Author Share Posted January 14, 2009 Is it empty when its cold, it should be approximately half full. Yeah. Empty when cold and hot, although the radiator is full when cold. Link to comment Share on other sites More sharing options...
Dnk Posted January 14, 2009 Share Posted January 14, 2009 Yeah. Empty when cold and hot, although the radiator is full when cold. Fill it approx halfway when cold then warm the car up and check the tank. Link to comment Share on other sites More sharing options...
AdzC Posted January 14, 2009 Author Share Posted January 14, 2009 Fill it approx halfway when cold then warm the car up and check the tank. Thanks. I'll give it a try. So when cold the overflow should be halfway up and when hot should be higher? Link to comment Share on other sites More sharing options...
edge Posted January 14, 2009 Share Posted January 14, 2009 The overflow tank is an expansion tank So as the coolant gets hot it expands. A couple of ways to do this Get engine upto Full running temperatre and fill the tank to nearly full. or Let the engine cool off overnight and make sure you just enough coolant in the tank to cover the bottom of the pipe to prevent it sucking air in. If when hot it over flows and when it cools it will take all the coolant out and leave with none causing air problems so you will need a larger expansion tank. Link to comment Share on other sites More sharing options...
