Mines Auto-ECU
Guest sunnyG83
Guest sunnyG83
i have for sale a Mines Auto-ECU for a 2jz-gte. This is currently being run on my Auto-TT. I also understand that this can be used on a Manual-TT also.
I am looking for £200 delivered + your standard auto-ecu. I require the standard ECU to replace the mines ECU which is being removed from my car.
Removes fuel cut/ speed cut. Raises rev limiter, more agressive map (ignition/timing), ideal for stock/ bpu.
Just as a heads up for anyone wanting to buy this, i have been told many times that normal pump fuel (95ron) should not be used with this. I know that most people on here are running higher octane fuel but you never know.
Thanks for looking
Guest sunnyG83
To be honest guys i have no real world answer as in dyno graphs but i must say that it feels like she pulls a bit harder and generally runs a little smoother too.
Like i said i cannot prove any of this via graphs but it does feel as though she is performing better.
I am trying to generate funds so am going back to stock ecu.
Plus if you already have a fcd/sld then you can remove these and sell them as they will no longer be needed.
I liked it when i changed from standard.
Guest sunnyG83
Hi i am sure that this is already pre-mapped for 1.1bar. I am un-aware if these can be sent back to Mines to be altered.
This is a direct replacement for your standard unit but with the added extra's and the 1.1bar Map so it should be more capable of making your car a little more powerful.
Like i said before, i really liked this unit when i bought it and it a nice add-on for the chaps running BPU.
i RATE IT ;-)
