Guigsy Posted December 28, 2008 Share Posted December 28, 2008 Right. The answer might be simple but im useless at this kind of thing. I got a lava lamp for Xmas which was sent to me from someone in the usa. Which is great. I love lava lamps. It obviously comes with an american plug which isnt a problem because i have a plug converter. But the bulb is rated at 120v (25w) all the stickers in the base say "only use 120v" etc. Now, can i simply pop out and buy a 240v (25w) bulb like i would use in my other lava lamp and it will all work fine because it will be getting 240v from the plug? Or will it just fry the wireing anyway? Im guessing i might have to buy a different base + plug but i dont want to as the base is a nice blue colour and ive only ever seen silver ones. Link to comment Share on other sites More sharing options...
Dave17 Posted December 28, 2008 Share Posted December 28, 2008 SUrely if you put in a higher voltage bulb it just wouldn't light and actually be able to get hot enought to heat the fluid? Link to comment Share on other sites More sharing options...
Homer Posted December 28, 2008 Share Posted December 28, 2008 Link to comment Share on other sites More sharing options...
michael Posted December 28, 2008 Share Posted December 28, 2008 http://www.maplin.co.uk/Module.aspx?ModuleNo=19413 Link to comment Share on other sites More sharing options...
Guigsy Posted December 28, 2008 Author Share Posted December 28, 2008 SUrely if you put in a higher voltage bulb it just wouldn't light and actually be able to get hot enought to heat the fluid? well my thinking is that the bulb is getting the correct voltage anyway after you change it as the wall is 240 and the bulb is rated for 240 not 120. I havent tried anything yet as i dont want to kill myself Link to comment Share on other sites More sharing options...
Guigsy Posted December 28, 2008 Author Share Posted December 28, 2008 http://www.maplin.co.uk/Module.aspx?ModuleNo=19413 Thanks michael. once again you save the day Link to comment Share on other sites More sharing options...
JustGav Posted December 28, 2008 Share Posted December 28, 2008 Strictly speaking if it is JUST a light bulb and nothing else in the circuitry you are fine. 25w is 25w be it at 120v or 240v. If you change it with a 240v 25w it should work the same. Personally I'd be cautious though... Link to comment Share on other sites More sharing options...
Dave17 Posted December 28, 2008 Share Posted December 28, 2008 Waiting for the post now all about how Guigsy has melted his fingers on his new lava/flesh light Link to comment Share on other sites More sharing options...
Guigsy Posted December 28, 2008 Author Share Posted December 28, 2008 for the sake of 9 quid at maplins i think ill pop out and get one Link to comment Share on other sites More sharing options...
michael Posted December 28, 2008 Share Posted December 28, 2008 If your generous US friend is likely to send you anything with more grunt in the future they also do a 100w one for £19. Link to comment Share on other sites More sharing options...
Guigsy Posted December 28, 2008 Author Share Posted December 28, 2008 flesh light I think if you google that you will find it is something completely different Link to comment Share on other sites More sharing options...
Andy Blyth Posted December 28, 2008 Share Posted December 28, 2008 http://www.maplin.co.uk/Module.aspx?ModuleNo=19413 You could risk it and use a 240V bulb connected to our mains, but there is no way of knowing what the insulation on the cable is rated to. Chances are it will work at first, but given time you risk the insulation ageing and breaking down, leading to possible arcing and potential fire. indeed! Link to comment Share on other sites More sharing options...
Dave17 Posted December 28, 2008 Share Posted December 28, 2008 http://www.fleshlightuk.com/catalog/default.php?cPath=21 Link to comment Share on other sites More sharing options...
Guest CoolsBlue Posted December 29, 2008 Share Posted December 29, 2008 I think if you google that you will find it is something completely different Link to comment Share on other sites More sharing options...
Guigsy Posted December 30, 2008 Author Share Posted December 30, 2008 ok just got one of them adaptor things from maplin... Doesnt work Rated for 45w - which is fine because the lamp is 25w. The output of the adaptor is 110 which is fine. Plugged it all in and flipped the switch expecting a light or at the least a fizz noise followed by a pop followed shortly after by smoke however there was nothing. Checked the adaptor for a seperate power switch or something, which there isnt. There is a power switch on the chord to the lamp but it makes no difference. Bit miffed now. Im gonna take the whole lot down to maplin so i can maybe check in the store i have the right one or if the adaptor i have is broken maybe. Link to comment Share on other sites More sharing options...
ivan Posted December 30, 2008 Share Posted December 30, 2008 Maybe the bulb's already blown. Link to comment Share on other sites More sharing options...
Guigsy Posted December 30, 2008 Author Share Posted December 30, 2008 nope the bulb is fine Link to comment Share on other sites More sharing options...
