akallis Posted March 19, 2005 Share Posted March 19, 2005 I have a toyota supra jap spec tt and had a replacement engine , since the engine was fitted the slip contorl light flashes constantly. It worked fine before the engine swap!! Any ideas what the problem could be? its been in the garage numerous times and they have had no luck sorting it! Link to comment Share on other sites More sharing options...
Barry Posted March 19, 2005 Share Posted March 19, 2005 I think it does this when its not connected. Check that its connected on the inlet maniford to the servo that controls the flap (its near the throttle flap). Link to comment Share on other sites More sharing options...
Terminator Posted March 19, 2005 Share Posted March 19, 2005 The cause for this could be numerous. Check the plugs to the throttle body are all pushed fully home particulalry the sub throttle. Check the TC fuse is not blown. I doubt they would have touched it but check the TC relay in the ABS /TC relay cluster near the OS front strut is OK, there are only three in there the other socket should be empty. Is the connector to the switch plugged in it is very easy to over look. They could have nicked a wire:swear: Link to comment Share on other sites More sharing options...
