jimmy_supra Posted November 12, 2008 Share Posted November 12, 2008 I have got a 95 tt auto J-Spec freshly imported this year. I want to get the cam belt changed as it has done 60,000 miles. What cambelt should I get? It is bpu. I would also like to change the pulleys, again which are best? Also are there any other parts I need to purchase for this job i.e tensioner kit or anything else? Thanks Link to comment Share on other sites More sharing options...
Scooter Posted November 12, 2008 Share Posted November 12, 2008 Stock belt............ If mileage is genuine i'd expect everything else (ie all listed below) to be ok. Absolute top job (but as i say probably mostly uneccessary) would be.... Water pump Cambelt Tensioner Tensioner Wheel Cambelt Crank Pulley Link to comment Share on other sites More sharing options...
jimmy_supra Posted November 12, 2008 Author Share Posted November 12, 2008 Stock belt............ If mileage is genuine i'd expect everything else (ie all listed below) to be ok. Absolute top job (but as i say probably mostly uneccessary) would be.... Water pump Cambelt Tensioner Tensioner Wheel Cambelt Crank Pulley When I bought it, it came with genuine paperwork form japan stating 84,500 km. It has now done 90,000km was converted to miles at 87,000km Link to comment Share on other sites More sharing options...
jimmy_supra Posted November 12, 2008 Author Share Posted November 12, 2008 I think I may get all but the water pump for now. Where is best to get these parts from and which ones are best oem? How much for them all? Thanks Link to comment Share on other sites More sharing options...
merckx Posted November 12, 2008 Share Posted November 12, 2008 I would also like to change the pulleys, again which are best? Any particular reason for wanting to change them? Link to comment Share on other sites More sharing options...
Scooter Posted November 12, 2008 Share Posted November 12, 2008 Any particular reason for wanting to change them? Indeed i have an NA on the best part of 100K miles and its on its original everything thats listed (bar cambelt obviously!) Given my NA is higher geared i think its tensioner wheel water pump etc has done approx twice the revolutions of your auto TT and i'm in no hurry to change these bits. Link to comment Share on other sites More sharing options...
jimmy_supra Posted November 13, 2008 Author Share Posted November 13, 2008 Any particular reason for wanting to change them? No particular reason I just thort it was best to do it all together. I was thinking of lighter aftermarket pulleys. I was advised that when doing the cambelt it was advisable to change the tensioner aswell. Maybe its not true, i'm no expert on these cars or cambelts still learning Link to comment Share on other sites More sharing options...
Rob Posted November 13, 2008 Share Posted November 13, 2008 No particular reason I just thort it was best to do it all together. I was thinking of lighter aftermarket pulleys. I was advised that when doing the cambelt it was advisable to change the tensioner aswell. Maybe its not true, i'm no expert on these cars or cambelts still learning Is that some subliminal advertising sneaking into your post? Usually, it is sound advise to change tensioners and pulleys when changing cambelts. However on the Supra these items are particularly well engineered and will last a long time. I did my 120,000mile cambelt change and the tensioner and pulley were perfect. Tensioner is about £90 from Toyota by the way, probably a lot more now. Link to comment Share on other sites More sharing options...
jimmy_supra Posted November 13, 2008 Author Share Posted November 13, 2008 Is that some subliminal advertising sneaking into your post? Usually, it is sound advise to change tensioners and pulleys when changing cambelts. However on the Supra these items are particularly well engineered and will last a long time. I did my 120,000mile cambelt change and the tensioner and pulley were perfect. Tensioner is about £90 from Toyota by the way, probably a lot more now. Thanks, i'll leave it then if it is going to be ok, as for the subliminal advertising that was just me writing in text language instead of writing in proper english. Link to comment Share on other sites More sharing options...
Rob Posted November 14, 2008 Share Posted November 14, 2008 that was just me writing in text language instead of writing in proper english. kthxbai Link to comment Share on other sites More sharing options...
