Guest pete g Posted March 10, 2005 Share Posted March 10, 2005 Does anybody in here know where i can get some headlight bulbs from for my j-spec? I probably sound stupid but i know the part numbers and ive tried all the big retailers (halfords, motorworld etc..) and they never seem to fit!!! I first tried some upgraded blue bulbs in which they fit fine into the back of the light but the electrical connections were wrong. So.... i then tried some standard ones in which i was pleased to find that the electrical connectors were correct but they wouldnt fit into the back of the light!!!! I had to resort to cutting and shaping the 3 fins on the light to fit them in(which isnt really ideal) If anybody knows where i can get some ice white or blue tint bulbs from that will fit a j-spec and not a uk could you please please let me know!! Link to comment Share on other sites More sharing options...
tepster Posted March 11, 2005 Share Posted March 11, 2005 u just asked my question-- good man! i need blue bulbs for a j spec too Link to comment Share on other sites More sharing options...
tbourner Posted March 11, 2005 Share Posted March 11, 2005 9006 bulbs. You need to cut one of the tabs off for it to fit into the holder. Link to comment Share on other sites More sharing options...
nuttynutz Posted March 11, 2005 Share Posted March 11, 2005 to what i know, the bulbs are 9005 and 9006, but slight adjustment needed to the tabs. the correct fit is however 9005J, 9006J, but i cant seem to locate these anywhere. tbourner, do you remember which tab it is that needs to cut off? they are spaced out like a Y so im guessing its the bottom tab if that make sence?? Link to comment Share on other sites More sharing options...
tbourner Posted March 11, 2005 Share Posted March 11, 2005 I'm not sure. I think someone on here said you can get 9006 for both main and dipped on the j-spec and just cut the tab off for both. The 9005 doesn't fit the main beam place apparently. Link to comment Share on other sites More sharing options...
_Lick_ Posted March 11, 2005 Share Posted March 11, 2005 I'm not sure. I think someone on here said you can get 9006 for both main and dipped on the j-spec and just cut the tab off for both. The 9005 doesn't fit the main beam place apparently. Wrong way round, the 9006 does not fit. This thread should assist... http://www.mkivsupra.net/vbb/showthread.php?t=29931&highlight=9005+bulb Link to comment Share on other sites More sharing options...
Nic Posted March 12, 2005 Share Posted March 12, 2005 The correct bulb spec is: J-Spec High Beam = 9005J Low Beam = 9006J UK Spec High Beam = 9005 Low Beam = 9006 The J has a different bulb fitting as you can see on the attached diagrams. These are only available in Japan as far as I can tell. If you want to fit new bulbs in the J-Spec the 9005 will fit in both High and Low, high beam will need very slight mod to the tabs. Link to comment Share on other sites More sharing options...
Guest pete g Posted March 12, 2005 Share Posted March 12, 2005 cheers for all the help everyone, i shall get on the case and give it a try! Link to comment Share on other sites More sharing options...
Toms Supra Posted March 12, 2005 Share Posted March 12, 2005 Yeah Nic is correct 9005 for both, you have to snip half off the two bottom tabs on the bulbs to get them to fit. I got mine off ebay. £8.99/pair. Bargain and they look lovely! Link to comment Share on other sites More sharing options...
nuttynutz Posted March 12, 2005 Share Posted March 12, 2005 ahh crap, so 9006 dont fit at all? i've just bought a pair of 9006 and 9005 aswell. Link to comment Share on other sites More sharing options...
Toms Supra Posted March 12, 2005 Share Posted March 12, 2005 No mate the 9006 is just too big to fit in hole, impossible to fit really. (diameter of 9006 bulbs is too wide for headlight hole). You will have to get another set of 9005`s. Link to comment Share on other sites More sharing options...
tepster Posted March 13, 2005 Share Posted March 13, 2005 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=28644&item=7960562772&rd=1 will these work?? they look like they are in a bulb holder already.. or am i being a :twat: Link to comment Share on other sites More sharing options...
