heartworm Posted September 2, 2008 Share Posted September 2, 2008 I have an Auto TT here with all the bits attatched to it, at the weekend the garage is going to start pulling it out to put into my 5spd N/A. What parts do I need to get a hold off since its going into a manual, and its from an auto? Please make this an easy list to understand...im not very teechnical with cars! Link to comment Share on other sites More sharing options...
couv3z Posted September 2, 2008 Share Posted September 2, 2008 your best bet would be to ask Jezz or steve at QSD, they're kind of experts at it........(not saying that other people arn't) they did my conversion and 5 spped is fun Link to comment Share on other sites More sharing options...
heartworm Posted September 2, 2008 Author Share Posted September 2, 2008 your best bet would be to ask Jezz or steve at QSD, they're kind of experts at it........(not saying that other people arn't) they did my conversion and 5 spped is fun I used to drive a 6 spd TT, sold it, missed it and bought my current N/A Link to comment Share on other sites More sharing options...
couv3z Posted September 2, 2008 Share Posted September 2, 2008 can't comment on the difference in 6 vs 5 bar the fact the guys said it would pull quicker because of the different gearing...(waits to get corrected) Link to comment Share on other sites More sharing options...
Homer Posted September 2, 2008 Share Posted September 2, 2008 There's a bit of an issue with connecting one of the TT ECU plugs to the NA fusebox. Miko_supra and Jezz were a great help solving this on my conversion, some details can be found here: http://www.mkivsupra.net/vbb/showpost.php?p=2073824&postcount=2 It's an essential one to solve otherwise the car won't run correctly. Also make sure you change the Radiator for a TT one as the NA one is tiny. You'll also need the induction system from a TT and obviously the ECU and engine loom. Same for the first cat if it's not already on the engine. Not sure about the clutch/flywheel situation on the 5spd or if the NA flywheel can be used on the TT, but I'm sure someone can advise. Will add more as I think of them! Link to comment Share on other sites More sharing options...
couv3z Posted September 2, 2008 Share Posted September 2, 2008 (edited) Not sure about the clutch/flywheel situation on the 5spd or if the NA flywheel can be used on the TT, but I'm sure someone can advise. this one i can help on the stock 5 box clutch can handle stock ttpower, but i was advised to replace it with a better one i've got a rps one, and feels no different to the stock clutch but will hold up to bpu(+) wow i think this has been my most helpful thread ever? Edited September 2, 2008 by couv3z grammer (see edit history) Link to comment Share on other sites More sharing options...
heartworm Posted September 2, 2008 Author Share Posted September 2, 2008 There's a bit of an issue with connecting one of the TT ECU plugs to the NA fusebox. Miko_supra and Jezz were a great help solving this on my conversion, some details can be found here: http://www.mkivsupra.net/vbb/showpost.php?p=2073824&postcount=2 It's an essential one to solve otherwise the car won't run correctly. Also make sure you change the Radiator for a TT one as the NA one is tiny. You'll also need the induction system from a TT and obviously the ECU and engine loom. Same for the first cat if it's not already on the engine. Not sure about the clutch/flywheel situation on the 5spd or if the NA flywheel can be used on the TT, but I'm sure someone can advise. Will add more as I think of them! Yep, I have the Induction system, ECU, Loom and radiator out of the car the engine came from, I have a new clutch for the 5 spd, but hadn't even thought about the flywheel. this one i can help on the stock 5 box clutch can handle stock ttpower, but i was advised to replace it with a better one i've got a rps one, and feels no different to the stock clutch but will hold up to bpu(+) wow i think this has been my most helpful thread ever? Thanks, looking forwarad to that TT power again Link to comment Share on other sites More sharing options...
Homer Posted September 2, 2008 Share Posted September 2, 2008 Yep, I have the Induction system, ECU, Loom and radiator out of the car the engine came from, I have a new clutch for the 5 spd, but hadn't even thought about the flywheel. Just make sure you read the links on those threads as unless you change the engine bay loom (not the same as the engine loom) you will need to make the fusebox mod. It's one of the biggest issued with the conversion if not done correctly. Link to comment Share on other sites More sharing options...
