removing crank pully.....again
marc_p
Ok , so basically I have removed the 22mm bolt holding the pulley on but cant actually remove the pulley, it's almost like it's welded itself on, is there a special way to remove the pulley?
Cheers
Marc
p.s. I did search first but couldn't find anything on this issue.
I made a Heath Robinson style puller from two bolts and a flat piece of metal. Drilled two holes in the metal and put each bolt through a hole and then into the pulley. Then wind out the pulley bolt against the flat metal, which pulls the pulley off the crank.
Edited by Jake (see edit history)
Phew, well I just tried it again (with a much stronger bar that didn't bend) and then whacked it like billy joe with a small hammer and eventually it came off. Cheers for the help anyway Jake, at least I knew I was doing the right thing.
glad you got it off mate, am going to be doing mine next weekend:rolleyes:
Just keep telling yourself 'it will come off' and eventually you'll get there :D
Anyway it's all back together now so looking forward to driving it as i've only had it 4 days in the last month.
