UltraFlynn Posted June 30, 2008 Share Posted June 30, 2008 I replaced by ABS bulb last night and realised that I have (or at least I think I have) another bulb not working next to it. Does anyone have a list/diagram of each of the warning lights on both sides of the dashboard please? I may have another one gone on the other side also. Link to comment Share on other sites More sharing options...
UltraFlynn Posted June 30, 2008 Author Share Posted June 30, 2008 I'll probably pull the units apart tomorrow and see what icons are printed on them. Link to comment Share on other sites More sharing options...
Homer Posted June 30, 2008 Share Posted June 30, 2008 The lights on the right hand side of the console have a habit of not working, is it not just a dry solder joint? (Very common Fault) IIRC there should also be an orange engine warning light, an orange oil level light and a red oil pressure light. When you first turn the ignition onto '2' it should light up all of them including the ABS. If you need any pics let me know, I have a couple of units in front of me now Link to comment Share on other sites More sharing options...
UltraFlynn Posted June 30, 2008 Author Share Posted June 30, 2008 Very handily I bought my first soldering iron today so if replacing the bulb doesn't work then re-soldering the joints will be my next task. Two two lights that I don't think are working are the one next to the ABS light (which is on the left hand of the dashboard) and on the right hand side of the dashboard the light furthest left in the cluster. Link to comment Share on other sites More sharing options...
Homer Posted June 30, 2008 Share Posted June 30, 2008 Is your one a UK or jspec car? I think there are some differences... Link to comment Share on other sites More sharing options...
UltraFlynn Posted July 1, 2008 Author Share Posted July 1, 2008 J-Spec Link to comment Share on other sites More sharing options...
