allawyg Posted June 21, 2008 Share Posted June 21, 2008 Single Turbo/Big Twins @ upto 1.3bar NGK - BCPR7ES (3330) - gap 0.7mm NGK - BKR7E (6097) - gap 0.7mm NGK - BKR8E - gap to 0.7mm NGK Iridium - BKR7EIX/BKR8EIX - leave gap alone Denso Iridium - IK24 - leave gap alone Ive seen this in the FAQ guide what does it mean by gap 0.7mm Can I just buy these plugs and put them in as normal, or do I have to make some adjustments Link to comment Share on other sites More sharing options...
Nic Posted June 21, 2008 Share Posted June 21, 2008 Most spark plugs come pre-gapped, but you should really check the gap between the electrodes before fitting and adjust as needed. You will need a feeler gauge to check the gap. Link to comment Share on other sites More sharing options...
allawyg Posted June 21, 2008 Author Share Posted June 21, 2008 cheers mate:) great help Link to comment Share on other sites More sharing options...
