The Raven Posted May 29, 2008 Share Posted May 29, 2008 Ok, running vista basic, I have done a total reformat and install. The Pc runs fine then at random times the screen freezes. 1. two dotted black lines show at the bottom of the page 2. a fuzzy bar shows at the top (like a non tuned tv fuzz) 3. tiny little flicky lights show on screen. This has been happening for 4 days now the only way to get out of it is to power off. The times are always different and it does not seem to matter what i am doing. Times of it doing it range from 2 minutes to an hour. Link to comment Share on other sites More sharing options...
MrRalphMan Posted May 29, 2008 Share Posted May 29, 2008 Sounds like the box is overheating. If it's a old box try blowing the dust out dude. Link to comment Share on other sites More sharing options...
The Raven Posted May 29, 2008 Author Share Posted May 29, 2008 I should add its a lap top. The air intake is on the bottom? and its chucking loads of hot air out of its side vent. Link to comment Share on other sites More sharing options...
The Raven Posted May 29, 2008 Author Share Posted May 29, 2008 Taken bottom of the case off, the fan was clear however and this may sound dumb. The panel i removed to gain access to the fan has 12 vents on the bottom of it but they are all covered with a silver backed black plastic. This isnt where its supposed to draw air in from is it? If it is then its air tight and nothing is getting in there. Link to comment Share on other sites More sharing options...
Scott Posted May 29, 2008 Share Posted May 29, 2008 That sounds a bit iffy buddy. Could you post any pics of what your talking about? Most lappys have a few impeller type fans that pull the air in through the bottom and push it out through heatsink fins and then out the back. If there is plastic in front of the heatsinks, between the fan and the heatsink or the heatsink and outside of the lappy, then there is something wrong. Is the black plastic below where the fans are? Sounds very strange. Link to comment Share on other sites More sharing options...
The Raven Posted May 29, 2008 Author Share Posted May 29, 2008 The air is coming out just fine no block between where the fan is and the outside of the laptop. I will take pics inbetween crashes of the bit im talking about i might be totaly wrong but it seems strange to me. Link to comment Share on other sites More sharing options...
The Raven Posted May 29, 2008 Author Share Posted May 29, 2008 http://img88.imageshack.us/img88/410/pc001zu5.th.jpg Thats it then the fan is over by the power lead. Like is said those vents dont go anywhere they are sealed with silver backed black plastic Link to comment Share on other sites More sharing options...
DamanC Posted May 29, 2008 Share Posted May 29, 2008 http://img88.imageshack.us/img88/410/pc001zu5.th.jpg Thats it then the fan is over by the power lead. Like is said those vents dont go anywhere they are sealed with silver backed black plastic Thats normal for a fujitsu fella. How old is it? Link to comment Share on other sites More sharing options...
ivan Posted May 29, 2008 Share Posted May 29, 2008 I suspect it's like that to force the airpath in over another hot component instead of straight into the fan. Link to comment Share on other sites More sharing options...
The Raven Posted May 29, 2008 Author Share Posted May 29, 2008 Bugger 6 months old its truly awful loads of the screws have simply fallen out of the case!!! Been running now for 4 hours without a problem Link to comment Share on other sites More sharing options...
DamanC Posted May 29, 2008 Share Posted May 29, 2008 I would rule out the dust by giving it a clean. Get some compressed air and squirt it into all available vents etc Link to comment Share on other sites More sharing options...
AlexJames Posted May 29, 2008 Share Posted May 29, 2008 Maybe im being dense but it sounds like a graphics card problem to me? Link to comment Share on other sites More sharing options...
DamanC Posted May 29, 2008 Share Posted May 29, 2008 Maybe im being dense but it sounds like a graphics card problem to me? Yeah, you are proably right. Its probably overheating The artifacts (point 3) give it away Link to comment Share on other sites More sharing options...
chilli Posted May 29, 2008 Share Posted May 29, 2008 Ok, running vista basic, well here is the first and most fundamental problem Link to comment Share on other sites More sharing options...
