Bolts for undertray
razza
I seemed to have a couple missing. I'm after the ones with washers on that go at the front of the undertray, linking it to the smaller undertray under the front bumper and the car. Without them the tray's hanging down a bit.
Thanks.
Did you buy new ones? if so where from?
Which ones do you need as there are three types of screws/bolts from memory. I'll write down the part numbers and a description of what each one is and let you decide form there :)
There only seems to be about 6 or 7 common type bolts/screws used all over the place (i'm sure someone will correct me). Would be cool to be able to just buy a large bag of common screws and bolts and just replace them as they are removed on different projects.
I have two numbers, the first one is 90119-06361 (Bolt W/Washer) and the bolt length is 16mm overall. The other number is 90119-06355 (Bolt W/Washer) and the bolt length is 24mm overall. I don't have my tray fitted at the moment so maybe someone will be kind enough to tell you which length you need.
Both the above bolts have quite large washers. I also have the following part number 90159-50311 (Screw W/Washer). This seems a common screw with a smaller washer that is used around the front wheel arch area.
