CarlT67 Posted May 9, 2008 Share Posted May 9, 2008 Tomorrow I am going to be replacing my brake hoses and was wondering what is the best way to bleed them, do one at a time...replace the hose and bleed through the caliper, or replace all hoses then bleed one at a time. Also if I do the second method what order is correct for bleeding i.e which corner first second etc.... Link to comment Share on other sites More sharing options...
dannypunto Posted May 9, 2008 Share Posted May 9, 2008 im about to do the same thing, i did do a serch and read about it somwhere? Link to comment Share on other sites More sharing options...
Swampy442 Posted May 9, 2008 Share Posted May 9, 2008 I changed my fronts last weekend, its not a hard job. If at all poss prime the lines with fluid first before you fit them, I fitted the hose then bled through the caliper, 1 at a time. If you do all 4 then bleed, I believe conventional wisdom is to bleed furthest from the master cylinder first and them work towards it. Link to comment Share on other sites More sharing options...
