Kicker 2 channel amp IX1302
BIG BLUE
I have removed my boot build and am currently selling the following, high end, 2 channel amp.
The amp sounds great and is in good condition (I am a perfectionist), so I may be underselling the condition.
This amp was several hundred pounds and would be ideal to liven up front or rear component speaks and can easily be tucked away under the boot carpet, etc as required,.
In the photo, the amp being sold is the top one, not the lower one.
SPEC:
Features
RCA Line Outputs: In addition to the stereo set of RCA inputs, there is a stereo set of full range line outputs. The line outputs allow you to pass a preamp level signal from this amplifier to another amplifier. This eliminates the need to use RCA splitter cords to distribute signals to two amplifiers.
Speaker Level Inputs: High level input connections are included to allow use with sources that do not have RCA preamp level outputs.
Built-in Electronic Crossover: Allows you to select high pass for satellite speakers, low pass for subwoofers or bypass for full range operation. Two crossover frequencies are available, 70Hz and 110 Hz, selectable for both high pass and low pass.
Protection Circuits: Auto-resetting short circuit and thermal protection circuits are included to protect the amplifier from failure due to extreme conditions.
Internal Circuitry: Includes MOSFET power supply and glass epoxy circuit boards.
KICKEQ Bass and Treble Boost: These bass and treble controls allows you to tune your system for ideal sound quality. The KICKEQ bass boost is centered at 40Hz, and it is continuously variable from 0 to +18dB. The KICKEQ treble boost is centered at 18kHz, and it is continuously variable from 0 to +12dB.
Included Connection Accessories:
2 crimp-on spade terminals (each has a red insulator): for +12V and ground connections
4 crimp-on spade terminals (each has a yellow insulator): 4 are used with speaker outputs
1 crimp-on spade terminal (includes a blue insulator): to attach remote turn-on wire
Fuses: two spare 25-amp fuses
Molex harness: to use with speaker-level connections
Four 1/2" rubber washers: use with supplied 3/4" screws to mount the amplifier; washers attach to bottom of amplifier at mounting hole locations
Four 3/8" plastic washers: use with supplied 3/4" screws to mount the amplifier; attach to the top of amplifier at mounting hole locations
4 butt connectors: use to connect speaker wire to the included speaker-level input harness
Four 3/4" mounting screws: to mount amplifier
Controls
Left Side Of Amplifier:
Gain: rotary gain control that allows you to adjust the output level
Crossover Frequency Switch: allows you to select 70Hz or 110Hz
Crossover Mode Switch: allows you to choose high pass, low pass or full range
KICKEQ Level Controls: rotary controls that allow you to adjust bass and treble boost
Inputs and Outputs
Left Side of Amplifier:
High Level Input: molex plug input for included harness
RCA Output: gold-plated RCA line output jacks
RCA Input: gold-plated RCA line input jacks
Right Side Of Amplifier:
Speakers Outputs: gold-plated screw terminals (each terminal is 0.356" wide)
Fuses: two 25-amp fuses
12+ (power): gold-plated screw terminal (terminal is 0.519" wide)
REM (remote turn-on): gold-plated screw terminal (terminal is 0.347" wide)
GND (ground): gold-plated screw terminal (terminal is 0.519" wide)
Specifications
Dynamic Power Rating (measured at 14.4V):
Bridged Into A 4-Ohm Load: 520 x 1
Per Channel Into A 2-Ohm Load: 260 watts x 2
Per Channel Into A 4-Ohm Load: 175 watts x 2
Continuous Power Rating (measured at 12.5V):
Bridged Into A 4-Ohm Load: 400 watts x 1
Per Channel Into A 2-Ohm Load: 200 watts x 2
Per Channel Into A 4-Ohm Load: 130 watts x 2
Hi Charles
Just listed it on Ebay also. Yes Golddigga and I are going to the show on the 27th and could bring it then for you if you 100% want it? (I would have to cancel my Ebay listing now and don't want to do this unless it is sold for sure).
Thanks
Neil
