mrboost Posted July 22, 2002 Share Posted July 22, 2002 Whats the next step up from UK Brakes Brembo 6 pots ? What discs do you thing I should go for Link to comment Share on other sites More sharing options...
GavinL Posted July 22, 2002 Share Posted July 22, 2002 Originally posted by mrboost Whats the next step up from UK Brakes Brembo 6 pots ? What discs do you thing I should go for What wheels do you have? Link to comment Share on other sites More sharing options...
mrboost Posted July 22, 2002 Author Share Posted July 22, 2002 at the mo 18" tsw venoms but going for 19"s very soon Link to comment Share on other sites More sharing options...
GavinL Posted July 22, 2002 Share Posted July 22, 2002 Originally posted by mrboost at the mo 18" tsw venoms but going for 19"s very soon what are you after as a matter of priority stopping power or looks? Link to comment Share on other sites More sharing options...
Guest Terry S Posted July 22, 2002 Share Posted July 22, 2002 Originally posted by mrboost Whats the next step up from UK Brakes Brembo 6 pots ? What discs do you thing I should go for Better Pads & some cooling ducts. Link to comment Share on other sites More sharing options...
mrboost Posted July 23, 2002 Author Share Posted July 23, 2002 I am after pure stopping power. The UK brakes are the best brakes in a car I have ever come accross, but with the more power (no cat) they seem well not as good, I am putting castrol srf brake fluid in hopefully before billing, but with the mods planned to get her into 700 bhp mark, I'd rather do the brakes first. Brembo do a 6 pot conversion and tarox do a 12, Thinking might just try grooved discs alaround first... what you think ? boost Link to comment Share on other sites More sharing options...
Guest Terry S Posted July 23, 2002 Share Posted July 23, 2002 Originally posted by mrboost I am after pure stopping power. The UK brakes are the best brakes in a car I have ever come accross, but with the more power (no cat) they seem well not as good, I am putting castrol srf brake fluid in hopefully before billing, but with the mods planned to get her into 700 bhp mark, I'd rather do the brakes first. Brembo do a 6 pot conversion and tarox do a 12, Thinking might just try grooved discs alaround first... what you think ? boost I now have the kind of power you are after & I am not concerned with the stopping ability. A friend has a set of AP 6 pots & doesn't think they are any better than mine. I have groved discs, intermediate pads from Chris Wilson, & are just about to install cooling ducts to try & stop the front discs warping. I have done trackdays with this set up & the performed faultlessly. It's your money, bit I think a lot of the kits are asthetic. Until someone proves they can out brake me, then I'll stick with what I've got. Link to comment Share on other sites More sharing options...
Guest Nick Harris Posted July 23, 2002 Share Posted July 23, 2002 Found this on here, the supra 4 pots r one of the best performing brake setups around. they even out perform the brembo 6pot 320mm. ive seen some figures somewhere ill try and find them (found them). i doubt that u can get better brakes for yr supra esp for reasonable money. have a look:- Porsche Twin Turbo GT1 brakes (the best on ANY road car in the world produce 2060 Braking Horsepower. The Jap-spec Supra TT produce 1010 Braking Horsepower. The UK spec Supra TT 4 pots produce 1665 Braking Horsepower. (With the Mintex elliptic grooved discs 1760!) Standard Porsche 996 C2/C4 1590 Braking Horsepower Ferrari 456GT, 1480 BR/hp Lamborghini Muira (1966), 780BR/hp ?!?!?! Mercedes Brabus V12, 1950 BR/hp Maclaren F1 1670BR/hp Ferrari F1.....7000+ hot, 700, when cold! 2ltr Ford Mondeo Saloon 700 BR/hp More, Brembo/AP 6 pot system, to any car 320mm discs (same as my supra brakes) 1590 BR/hp 355mm discs 1680 BR/hp 385mm discs 2040 BR/hp Wilwood Rallystop (4pot) for the first 2 above sizes 1640 BR/hp 1750 BR/hp the above brake info taken from soarer site, sourced by iain wiltshire. --------------------- i think the C2/4 Porsch runs Brembos. lokking for the Mintwx discs they sound good Link to comment Share on other sites More sharing options...
GavinL Posted July 23, 2002 Share Posted July 23, 2002 Originally posted by mrboost I am after pure stopping power. The UK brakes are the best brakes in a car I have ever come accross, but with the more power (no cat) they seem well not as good, I am putting castrol srf brake fluid in hopefully before billing, but with the mods planned to get her into 700 bhp mark, I'd rather do the brakes first. Brembo do a 6 pot conversion and tarox do a 12, Thinking might just try grooved discs alaround first... what you think ? boost It is possible that your brakes aren't working too there best so it may well be worth getting the caliper refurb kit as well as changing the fluid. Just taking the cat out shouldn't be an issue with UK spec brakes. I have stock discs and s/steel brake lines and Porterfield Race pads on my car and it stops very well. Like Terry's car I do have problems with warping discs. Get better pads before replacing disc's. Link to comment Share on other sites More sharing options...
Guest Nick Harris Posted July 23, 2002 Share Posted July 23, 2002 Whilst in Yokohama recently it seems every car shop recommends Endless pads, have just run a search and found this> He says that if you accord the standard Supra pads for the 4pots as '1' and the DS2500 that he had been using as '1.5' the NA-S is a '2', he says he can scrape the nose of his modded Supe on the road at full stop! The standard stuff hardly wears the disc, the DS2500 scrape the discs out in a year, the endless are more aggressive than the standard, his discs are 1mm thinner in just about a year, so I think they are OK, he states that cooling air is ESSENTIAL for endless pads as they generate more heat than any other pads he has ever encountered outside of Formula/GT racing, he assures me that almost all the Skylines he sees have Endless pads and they are making there way into every performance car in Japan! He actually complimented me on a good choice of Manufacturer!!! So I've ordered some, should be here end of the week after next! With posting £150. ----------------------- How much better were these pads. Mycroft and Chris Wilson were trying them but cant find any updates are they OK, as I have a colleague who stayed in Japan and will get him to send me a set if they are taht good. Link to comment Share on other sites More sharing options...
Guest Terry S Posted July 23, 2002 Share Posted July 23, 2002 Nick It's funny you should mention this. We have tried pretty much all pads now with the exception of Hawk, Panther & Endless. When Leon first got his car they had a very metallic pad with a blue backing. They were awesome. I now believe they may have been the Endless. I have details of the endless pads but cannot be sure which compound they were. Please keep me informed on which compound you receive & how they perform. FWIW where did you get yours from, as the only source I have found was in OZ & was quiet expensive. Gavin, I think cooling ducts may be essential. I have mine made up, I just need to get around to fitting them I'll send you some pictures when they are done. The other option is 2 piece discs to dissapate the heat better, but these seem expensive. Link to comment Share on other sites More sharing options...
Guest Nick Harris Posted July 23, 2002 Share Posted July 23, 2002 terry, havent found them yet Iwant to know more, the pads are in one of the threads here and thay are blue, if you type >endless the search engine above right BTW Link to comment Share on other sites More sharing options...
Guest Terry S Posted July 23, 2002 Share Posted July 23, 2002 Sorry Nick, I missed the jist of the thread Link to comment Share on other sites More sharing options...
Guest Terry S Posted July 23, 2002 Share Posted July 23, 2002 Originally posted by Nick Harris terry, havent found them yet Iwant to know more, the pads are in one of the threads here and thay are blue, if you type >endless the search engine above right BTW Nick, try this link http://www.belperformance.com.au/endless/bp_index.html Link to comment Share on other sites More sharing options...
Guest Nick Harris Posted July 23, 2002 Share Posted July 23, 2002 350 ozzy$ is about 120£ plus 30£ for posting, have sent chris wilson a PM >mycroft, doesn't accept PM Link to comment Share on other sites More sharing options...
Guest Terry S Posted July 23, 2002 Share Posted July 23, 2002 Also try http://www.endlessusa.com I think they will be fine, but I'll ask the US tech list if anyone has tried them. Link to comment Share on other sites More sharing options...
mrboost Posted July 23, 2002 Author Share Posted July 23, 2002 thanks for the good info guys, Yeah I need some more pads then and with the castrol srf fluid should be better. As for the ducts on the front brakes, have any of you done this...any pictures ? Martin Link to comment Share on other sites More sharing options...
GavinL Posted July 23, 2002 Share Posted July 23, 2002 Originally posted by Terry Saunders Gavin, I think cooling ducts may be essential. I have mine made up, I just need to get around to fitting them I'll send you some pictures when they are done. I would be very interested, thanks. Have you remove the gaurds at the rear of the disc's? I did recently as I think it will help a little. Link to comment Share on other sites More sharing options...
Guest Terry S Posted July 23, 2002 Share Posted July 23, 2002 Originally posted by GavinL I would be very interested, thanks. Have you remove the gaurds at the rear of the disc's? I did recently as I think it will help a little. Yeah they are off. I am sure it helps but I still warped them. I may change the rears as well as I think I may have warped those as well! Link to comment Share on other sites More sharing options...
Guest Terry S Posted July 23, 2002 Share Posted July 23, 2002 Nick, where did you get AUS$350 from? Link to comment Share on other sites More sharing options...
Guest Nick Harris Posted July 23, 2002 Share Posted July 23, 2002 Your link! Link to comment Share on other sites More sharing options...
Wez Posted July 23, 2002 Share Posted July 23, 2002 Hey Guys, Just a quick question, whats the difference between UK brakes and large J-Spec Brakes, my car is a 96 and came with 4 pots and 2 pots from Japland. Are they the same? Laters Wez Link to comment Share on other sites More sharing options...
GavinL Posted July 23, 2002 Share Posted July 23, 2002 Originally posted by Wez Hey Guys, Just a quick question, whats the difference between UK brakes and large J-Spec Brakes, my car is a 96 and came with 4 pots and 2 pots from Japland. Are they the same? Laters Wez They are the same........ Link to comment Share on other sites More sharing options...
Guest Nick Harris Posted July 23, 2002 Share Posted July 23, 2002 Whilst i was in yokohama isaw lots of the supras/soarers/j90's and 100's had the 4pot and 2 pot apparently taken from the Celica 4wd turbo, these brakes fit within the 16 inch rim and are ferocious for there size, they aremuch narrower than the supra 4pots adn you can getlots of different wheels for them, you dont need the splayed spoke type. supposed to be almost as good as the supra setup. Link to comment Share on other sites More sharing options...
Terminator Posted March 27, 2005 Share Posted March 27, 2005 Sorry to dig this old thread up:limp: But I have been trying to find a link to a chart that lists top production cars brake performace The list starts with a FI car and shows the MKIV UK brakes setup near the top:) . Any one have the link? Link to comment Share on other sites More sharing options...
