Odo showing KM not miles
JohnnyW
Afternoon all!
My odometer is reading in miles (as it should) but on the display km is lit instead of miles. How can you change it so it shows miles?
Cheers
Johnny
You may want to consider keeping it as it is!
For instance when it comes to selling your car you will have to explain how and when you or a company adjusted the KMs/milage...perfectly dooable, but may look a little suspect ;)
On the other hand if you don't care, there's bound to be a company that will do this for you :)
The problem is that the it counts up in miles but the km light is lit.
It used to be that miles was lit when I first got the car however after 6 months of stripping it to bits (it was accident damaged), connecting and disconnecting the battery, fitting an alarm etc etc it seems to have defaulted back to KM somehow!?!? I hadn't even noticed until 3 weeks ago.
Must learn to read thread properly, sorry :D
Hopefully some clever person will come along and tell you it's a simple wiring issue...have you done a search?
