VVTi de-catt
Supra Pilot
Thanks, so this confirms the Turbo pack is different then!
This is what I am not certain about as I have previously read(here) that the Turbo set between pre & post VVTi models carry the same part numbers.(which does not add up)
Then also just picked from more searching that the Turbos or the pack assy is indeed different... Which will confirm the fact the Mounting flanges are different........
So another question, are the Turbos/Turbo pack a different set up and whats the differences?
Besides the flanges, and if just flanges, why, are they a better design now?????
Anymore input appreciated.
Thanks
Is the difference re the decat pipe just a change in the last part of the "elephants leg"? The bit of cast iron that comes off the EGCV component and connects to the 1st cat pipe?
-Ian
not sure, only thing I know is that the O2 sensor on the second cat is removed on the vvt-i.. her`s a few pictures of the flane on the first cat.....
haven`t got any pictures of the rest....
