Mike B Posted January 20, 2008 Share Posted January 20, 2008 When you see sheet metal workers bashing sheets of metal to alter it's shape they use a technique with a hammer and a block behind the sheet... what's the process called?? Link to comment Share on other sites More sharing options...
BASHTHEBISHOP Posted January 20, 2008 Share Posted January 20, 2008 panel beating? Link to comment Share on other sites More sharing options...
Charlotte Posted January 20, 2008 Share Posted January 20, 2008 Banging really strongly. Link to comment Share on other sites More sharing options...
Lewis Posted January 20, 2008 Share Posted January 20, 2008 fettling? Or is that just the casting process? I ono?! Link to comment Share on other sites More sharing options...
Mike B Posted January 20, 2008 Author Share Posted January 20, 2008 panel beating.... yup, think so.. is there a more technical name? Link to comment Share on other sites More sharing options...
michael Posted January 20, 2008 Share Posted January 20, 2008 I think Charlotte may be right but it could also be "Planishing" ? Link to comment Share on other sites More sharing options...
Kranz Posted January 20, 2008 Share Posted January 20, 2008 fettling? Or is that just the casting process? I ono?! Fettling is the process of hammering or shot/sand blasting to remove sand from castings I believe. Also used to mean general filing or grinding to make something fit that doesn't quite Tin bashing is what I used to call it, but the correct term is indeed panel beating or sheet metal fabrication. Edit: Errr and what Michael said (who appears to have easy access to a dictionary:)) Link to comment Share on other sites More sharing options...
Ewen Posted January 20, 2008 Share Posted January 20, 2008 Sometimes called 'raising' to get the approx shape required, then 'planishing' to remove the larger dings caused in the initial shaping. Or at least that is what it was called when I was an apprentice. Link to comment Share on other sites More sharing options...
Lewis Posted January 20, 2008 Share Posted January 20, 2008 Fettling is the process of hammering or shot/sand blasting to remove sand from castings I believe. Also used to mean general filing or grinding to make something fit that doesn't quite Tin bashing is what I used to call it, but the correct term is indeed panel beating or sheet metal fabrication. That rings a bell, that's probably what made me think to add it to the post. Panel beating sounds like it should still have a "more proper" name though lol. Link to comment Share on other sites More sharing options...
Kranz Posted January 20, 2008 Share Posted January 20, 2008 Panel beating sounds like it should still have a "more proper" name though lol. See 'tin bashing' or 'pipe strangling' LOL Link to comment Share on other sites More sharing options...
Jake Posted January 20, 2008 Share Posted January 20, 2008 When you see sheet metal workers bashing sheets of metal to alter it's shape they use a technique with a hammer and a block behind the sheet... what's the process called??Metal Shaping or Panel Beating, according to my uncle who does it for a living. Link to comment Share on other sites More sharing options...
Rob Posted January 21, 2008 Share Posted January 21, 2008 I thought planishing is when you get thousands of little flat spots in a curved surface. However this shows that it was just my technique that was rubbish. Link to comment Share on other sites More sharing options...
Pot Posted January 21, 2008 Share Posted January 21, 2008 Frantic Solo Man Hammering? Link to comment Share on other sites More sharing options...
