standardsupra20 Posted January 1, 2008 Share Posted January 1, 2008 Ok here go's, I've got a n/a single turbo conversion with a six speed manual gearbox. I want to fit a twin turbo engine & then get Ryan to provide an ecu & map it etc. My question is, can I simply fit the replacement engine? Will the manifolds from the old n/a engine fit the replacement unit? Will the gearbox, clutch etc fit ok? What about electrics & air con? Please help, I can't decide whether to stick (350bhp) or twist (poss 600bhp) Cheers in anticipation, Keef. Link to comment Share on other sites More sharing options...
SupraHuman Posted January 1, 2008 Share Posted January 1, 2008 Your manifolds will not fit.And you will need a new ECU and wireing loom..Gearbox and clutch should fit straight on but you will need to upgrade the clutch if you plan to run 600hp. Link to comment Share on other sites More sharing options...
miko_supra Posted January 1, 2008 Share Posted January 1, 2008 all your electrics will be fine as will he the a/c (take the old a/c pump off of the old n/a engine leaving all the hoses attached to it and then hook that up to the TT engine when you come to fit it. this saves re gassing it. have you checked my n/a-tt thread it might help you Link to comment Share on other sites More sharing options...
Scooter Posted January 1, 2008 Share Posted January 1, 2008 I know someone who would be interested in the NA-T engine currently in the car if you are selling to fund the swap? Link to comment Share on other sites More sharing options...
standardsupra20 Posted January 2, 2008 Author Share Posted January 2, 2008 all your electrics will be fine as will he the a/c (take the old a/c pump off of the old n/a engine leaving all the hoses attached to it and then hook that up to the TT engine when you come to fit it. this saves re gassing it. have you checked my n/a-tt thread it might help you Thanks for your help, i'll have a gander at that thread. Link to comment Share on other sites More sharing options...
