liam1 Posted December 27, 2007 Share Posted December 27, 2007 im busy replacing me j spec with uk spec glass ones but the old bulbs wont go into the new headlights do i ned new bulbs Quote Link to comment Share on other sites More sharing options...
SteveR Posted December 27, 2007 Share Posted December 27, 2007 Yes - 2 ticks and I'll find a link Quote Link to comment Share on other sites More sharing options...
SteveR Posted December 27, 2007 Share Posted December 27, 2007 http://www.mkivsupra.net/vbb/showthread.php?t=59734 Quote Link to comment Share on other sites More sharing options...
fat_controller Posted December 27, 2007 Share Posted December 27, 2007 i think you can just trim the lugs down a little, put them against the whole and see how much needs to come off and then trim it with a stanley blade Quote Link to comment Share on other sites More sharing options...
jamesmark Posted December 27, 2007 Share Posted December 27, 2007 Plus do not waste your time with above link to normal bulbs, replace them with HID units. Quote Link to comment Share on other sites More sharing options...
SteveR Posted December 27, 2007 Share Posted December 27, 2007 Plus do not waste your time with above link to normal bulbs, replace them with HID units. Agreed. It was just meant as a handy guide to the bulb types, not a recommendation. Quote Link to comment Share on other sites More sharing options...
jamesmark Posted December 27, 2007 Share Posted December 27, 2007 Agreed. It was just meant as a handy guide to the bulb types, not a recommendation. I kinda guessed that, when he was asking if he needed other sizes. Quote Link to comment Share on other sites More sharing options...
SteveR Posted December 27, 2007 Share Posted December 27, 2007 I kinda guessed that, when he was asking if he needed other sizes. Well, you said don't waste your time with the link Quote Link to comment Share on other sites More sharing options...
jamesmark Posted December 27, 2007 Share Posted December 27, 2007 Well, you said don't waste your time with the link You need some Pantene. Quote Link to comment Share on other sites More sharing options...
SteveR Posted December 27, 2007 Share Posted December 27, 2007 You need some Pantene. UK or J-Spec? Quote Link to comment Share on other sites More sharing options...
Nic Posted December 27, 2007 Share Posted December 27, 2007 im busy replacing me j spec with uk spec glass ones but the old bulbs wont go into the new headlights do i ned new bulbs You should be able to make the high beam bulbs fit, the low beams you will need to buy a new pair of 9006/HB4. Quote Link to comment Share on other sites More sharing options...
