Numberplates
terribleturner
 Share
yeah but what the guy is saying is that it will be incorporated into the plastic part of a standard plate so that it won't be obvious. As long as the wiring to it is descreet theres quite a high possibility that you could drive around with the thing blanked out virtually permanently. If you get pulled by an unmarked car with video you could have a spot of explainin to do but apart from that you are gonna be pretty sorted. What you could do with in reality is something that just blurs the numbers up. They are not allowed to visually alter or use image rendering on any camera speeding device so you shouldn't get had by a camera that way. If the LED panel was instead of one entire panel just being an area around the numbers it would work a treat.
 Share
