Durandal Posted July 28, 2014 Share Posted July 28, 2014 So im working on changing my rear wheel bearings. I got the passenger side hub assembly off but the driver side is stuck on the axle. If i remove the 6 hex bolts holding the axle into the rear end will i lose my rear end fluid? I dont want to hit the end of the axle with it still connected to the rear end. Quote Link to comment Share on other sites More sharing options...
Guest Roger NE Posted July 28, 2014 Share Posted July 28, 2014 Do you mean the bolts connecting the drive shaft to the Differential? If so, yes you can unbolt it and you won't lose any oil out your diff. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 28, 2014 Share Posted July 28, 2014 They can be stuck on really tight, and need a good bash with a plastic faced mallet to free them. They are best freed by undoing all the cap heads a couple of turns then the car driven jerkily a yard or two forward and back to break them, free before you start dismantling. Not much use to you now, but may help someone else. Check the wheel flanges, if there's ANY signs of the inners of the bearings having been fretting or turning on the stub of the hub flange you MUST renew the flanges or it'll knacker the new bearings in no time. Same if there's a load of rusty dust telling you the dive shaft splines have been frettin inside the hub flange splines. Lots of loading and torque reversal in this area, has to be perfect or it'll give more grief later. Quote Link to comment Share on other sites More sharing options...
Durandal Posted July 28, 2014 Author Share Posted July 28, 2014 (edited) Thanks for the advice. A cloud of rust came out when i removed the axle from the hub on the other side. So are you saying that would be an indication of wear on the spline? Will try pulling the axle out of the diff on the stuck side and give it a smack. http://www.toyodiy.com/parts/diag_2p7S5p.png 43409A is the part number of the 6 10mm hex bolts i was referring to. Edited July 28, 2014 by Durandal (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 28, 2014 Share Posted July 28, 2014 Wire brush the splines on the outer CV joint, and inside the hub flange. *ANY* free play when you mate them back together is a sign of wear and things need replacing. Either, or both, the outer CV joint and / or the hub flange. Quote Link to comment Share on other sites More sharing options...
Durandal Posted July 28, 2014 Author Share Posted July 28, 2014 Success! Kind of http://imgur.com/DhMdJCF I am a little worried about what I found when removing lower control arms though. These are pictures of the passenger and driver side area where the lower control arms bolt to the frame of the car. I'm guessing the holes are suppose to be round? http://imgur.com/YWmSjub http://imgur.com/v1u3nl7 Can anyone verify if I have just uncovered a can of worms :| Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 29, 2014 Share Posted July 29, 2014 If the fixing bolt has a snail type adjuster on each end (nut and head) the hole should be slotted to allow suspension adjustment. If it's a plain bolt with no snails, the hole should be round. Quote Link to comment Share on other sites More sharing options...
Durandal Posted July 29, 2014 Author Share Posted July 29, 2014 ya it does have the adjusment on it. Thanks. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 29, 2014 Share Posted July 29, 2014 No worries, just make sure the bolts are torqued to spec when it goes back together. Quote Link to comment Share on other sites More sharing options...
Durandal Posted July 29, 2014 Author Share Posted July 29, 2014 Should I be ok to just centre the arms in the adjusment holes until I can get it to the shop for a full geo? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 29, 2014 Share Posted July 29, 2014 Y ou *SHOULD* have used Tipex to mark the snails positions relative to the sheet metalwork, so they could be returened to the original positions. I think the adjuster slot you are showing is for the rear toe adjustment, and I can just make out the witness marks of where the snails sat. If you can't determine their original position from the marks, you can aim mid way, but the handling may be very odd, rear toe is quite critical and causes more marked handling effects than front toe, so take care! Tyre wear will be alarmingly high if the rear toe is far out, too. Quote Link to comment Share on other sites More sharing options...
